WoJWoJ
1
I have successfully integrated my first Shelly 2.5 to manage a roller shutter. I used the Shelly integration and I see
Pressing the arrows moves the shutter, and the square stops it.
I now would like to understand how to tell HA “Open the roller stutter at 25%”. Is this possible?
(I will use this in an automation from AppDaemon and probably a button in Lovelace)
I have not used Shelly, but if the device resolves as a cover.something?
You can use this in a automation with this command:
- service: cover.set_cover_position
entity_id: cover.blind_somthing
position: 75
Perhaps you can rework this to work in appdeamon ?
Like making a switch if you always want it to a specific position.
Or i miss understood you
Hope it’s somewhat useful
