It appears in my Home Assistant web interface, with a slider to switch it on and off
When moving the slider, it goes to the “on” (blue) position and then goes back to “off”. At the same time, the lamp switches on.
This switch listens to the topic ch1-lampe-bureau/relay/0/set in order to change its state (this is successfully sent by HA), and subsequently sends a state value (0 or 1) to ch1-lampe-bureau/status.
I guess that Home Assistant does not recognize this 0 or 1 as being a proper state and I should be able to tell him what to expect.
What is the configuration entry I should use?
I saw something which may be a match:
state_value_template
(string)(Optional)Defines a template to extract the state value. The template should match the payload on and off values, so if your light uses power on to turn on, your state_value_template string should return power on when the switch is on. For example if the message is just on , your state_value_template should be power .
I just do not understand what this sentence mean (despite having an example - I just cannot place my 0 or 1 in this)
In the meantime I tried to interpret the state_value_template configuration item (which seems to be the only one which matches my use case) but they do not work
state_value_template: "{% if value == 0 %} 'OFF' {% else %} 'ON' {% endif %}"
or
state_value_template: "{% if value == '0' %} 'OFF' {% else %} 'ON' {% endif %}"
(I tried both in case the 0 is transmitted as a string or an int - which is not obvious from mosquitto output). I am not sure I understand the idea of the parameter at all, though.
I suggest you configure your MQTT light (are you using Tasmota?) to publish its state with retain=true. This ensures that when you restart Home Assistant, it will receive the light’s current state.
You need an MQTT tool like MQTTbox or MQTT.fx to see what MQTT messages and topics are going through your hub. If you are using Tasmota, I recommend you only change the topic variable in the setup. This makes the command and state topics more predictable.
You say the light is going on but the switch turns off a second later. This means that Home Assistant did not get a status from the switch.
Using your MQTT tool, subscribe to # and watch what MQTT messages are published when you turn the switch from Home Assistant on. You can also see what messages the Sonoff Basic publishes when you press the button.
@stevemann@nickrout I am not sure what was not clear in my question regarding this? (I would be glad to clarify)
I know which messages are sent and can read on the MQTT bus (either with mosquitto_sub but it is not practical as it does not show the topics, or I have a monitoring system which grabs every message (and its topic) anyway). I also mentioned them (and the whole timeline of what happens where) in the question.
@123 When HA sends an ON message to my switch (running Espurna) it gest correctly switched on (and, similarly, an OFF messages switches it off). I will try to change this to 1 and 0 (= force HA to send 1instead of ON etc.) and see if this works.
If it does it solves this exact problem (which is good already), but not the overall one of having different command and status messages for the state (hopefully solved via state_value_template)
If I had a switch that was controlled with on/off and reported its status with 1/0 then I would:
Re-program it!
Make it use on/offor1/0, not both. It’s neater and will prevent having to create a state_template in Home Assistant. If you can’t re-program it then maybe this template will work for you:
state_value_template: >-
{% set values = { '0':'off', '1':'on'} %}
{{ values[value] if value in values.keys() else 'off' }}
