Hello ,
I have created a sensor in esphome . This sensor has an update_interval of 1 second. This is necessary for other sensors to calculate their value.
I would like to manage the frequency of publication of this sensor in Home Assistant .
To do this, I had defined this sensor as internal: True
and via a trigger add component.update:
In the log, I see that the sensor publishes its status every second despite internal being set to True.
Do you have an idea for solving this problem?
here are the extracts from the yaml file (if you prefer the whole file, I can include it)
here are some of the sensors :
- platform: adc
pin: GPIO4
accuracy_decimals: 5
attenuation: 12db # see : esphome.io/components/sensor/adc.html since esphome 2024.5.0 change 11db to 12db
# on the ESP32-S2 page :Attenuation(db) :6 , suggested range (mV ) : 0 ~ 1300 , Attenuation(db) :11 , suggested range (mV ) : 0 ~ 2500
update_interval: 1s
internal: true
- platform: ct_clamp
sensor: adc_sensor_id_4
name: "Sensor Live Current Burner"
update_interval: 1s
accuracy_decimals: 3
device_class: current
unit_of_measurement: "A"
icon: "mdi:current-ac"
internal: true # This setting prevents it from publishing updates to Home Assistant directly. Instead, it just updates the global variable.
sample_duration: 200ms
filters:
- calibrate_linear:
method: exact
datapoints:
- 0 -> 0
- 0.009 -> 0.0 # zero load state :Raw AC Value: 0.019A
- 0.040 -> 0.14
# Override with a fixed value for testing
# - lambda: return 0.2; # Set to whatever fixed value you need to test the program
then the script :
script:
- id: check_threshold
then: # can't use a substution so need to be hardcoded , alternative create a global variable see above
- lambda: |-
if (id(burner_on).state) {
id(seconds_above_threshold_burner) += 1;
if (id(boiler_on).state) {
id(seconds_above_threshold_boiler) += 1;
if (id(house_on).state) {
id(seconds_above_threshold_house) += 1;
if (id(workshop_on).state) {
id(seconds_above_threshold_workshop) += 1;
- id: publish_and_reset
then:
- component.update: sensor_live_current_burner
- component.update: sensor_live_current_boiler
- component.update: sensor_live_current_house
- component.update: sensor_live_current_workshop
- component.update: ct1Watts
- component.update: ct2Watts
- component.update: ct3Watts
- component.update: ct4Watts
- component.update: seconds_per_minute_burner
- component.update: seconds_per_minute_boiler
- component.update: seconds_per_minute_house
- component.update: seconds_per_minute_workshop
- component.update: calculated_fuel_consumption
- lambda: |-
ESP_LOGD("custom", "Publishing Seconds: %d", id(seconds_above_threshold_burner) , id(fioul_l_per_hour) , id(fioul_used_since_refilling) );
float new_value = id(fioul_used_since_refilling).state + id(calculated_fuel_consumption).state;
id(fioul_used_since_refilling).publish_state(new_value);
# id(seconds_per_minute_burner).publish_state(id(seconds_above_threshold_burner));
# id(fioul_used_since_refilling) += id(calculated_fuel_consumption).state;
- globals.set:
value: '0'
- globals.set:
value: '0'
- globals.set:
value: '0'
- globals.set:
value: '0'
- delay: 1000ms # Ensure it delays slightly to avoid any race condition with last-second updates
substitutions: # if the value is static and won't change during runtime. Substitution variables are set at compile-time and are consistent across the device's firmware.
device_name: "chaudieres21"
device_friendly_name: "Chaudiere S2"
# device_platform: ESP8266
# device_board: d1_mini
device_area: Buanderie
publish_sec: '60' # interval for publishing the sensors data in Home Assistant in sec
globals: # if the value may need to change dynamically during runtime. Global variables are appropriate for values that might need to be updated based on conditions
# or events while the device is operating.
- id: publish_seconds # to use the substitution value inside a lambda, it needs to be set as a global variable's initial value
type: int
restore_value: no
initial_value: '${publish_sec}'
