Hi!
i forgot to set the file in the folder CONFIG/network/my-network
after i finished my install and now when i modify this file, it disappears from the boot-hassio folder.
I dont have access to the root ssh files.
Any ideas?
tried with these files:
[connection]
id=my-network
uuid=72111c67-4a5d-4d5c-925e-f8ee26efb3c3
type=802-11-wireless
[802-11-wireless]
mode=infrastructure
ssid=weirdwifinamehere
# Uncomment below if your SSID is not broadcasted
#hidden=true
[802-11-wireless-security]
auth-alg=open
key-mgmt=wpa-psk
psk=difficult_pass_here
[ipv4]
method=manual
address=192.168.1.111/24;192.168.1.1
dns=1.1.1.1;1.0.0.1;
[ipv6]
addr-gen-mode=stable-privacy
method=auto
[connection]
id=hassos-network
uuid=d55162b4-6152-4310-9312-8f4c54d86afa #you should probably generate fresh uuids for each connection, mine are from the examples in the hassos docos.
type=802-3-ethernet
[ipv4]
method=manual
address=192.168.1.112/24;192.168.1.1
[ipv6]
method=auto
[connection]
id=my-network
[802-11-wireless]
mode=infrastructure
#hidden=true
auth-alg=open
key-mgmt=wpa-psk
[ipv4]
method=manual
[ipv6]
method=auto
any ideas?
