Hi all,
I want to add my Yamaha RX-A740 receiver to Home Assistant (HA).
In a previous install of HA that worked for a short amount of time (a couple of weeks ago), but I have no idea anymore why it worked at that instance. Since, I moved on to an installation of HA (core-2021.11.2) on a Raspberry Pi 4.
I already tried multiple things such as running the discovery mode or adding the receiver manually in configuration.yaml. All without succes.
Below you can find the log when adding the receiver manually. Note that I can go to http://rx-a740-b58dc70:80/YamahaRemoteControl/desc.xml in my browser.
I also looked around for an answer on (probably) the important question in this case: is my receiver compatible with HA. Since it is not an RX-V one, I’m doubting it is (but then again, why did it work for an instant previously?).
I would appreciate some help or clarification on this topic.
PS: I’m a newbie to Home Assistant
2021-11-09 23:38:20 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [548117403008] Received invalid command: mobile_app/push_notification_channel
2021-11-09 23:38:25 ERROR (SyncWorker_1) [rxv] Failed to fetch http://rx-a740-b58dc70:80/YamahaRemoteControl/desc.xml
File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 174, in _new_conn
conn = connection.create_connection(
File "/usr/local/lib/python3.9/site-packages/urllib3/util/connection.py", line 73, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/local/lib/python3.9/socket.py", line 954, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 394, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 239, in request
super(HTTPConnection, self).request(method, url, body=body, headers=headers)
File "/usr/local/lib/python3.9/http/client.py", line 1279, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.9/http/client.py", line 1325, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.9/http/client.py", line 1274, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.9/http/client.py", line 1034, in _send_output
self.send(msg)
File "/usr/local/lib/python3.9/http/client.py", line 974, in send
self.connect()
File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 205, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 186, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f9e561df0>: Failed to establish a new connection: [Errno -3] Try again
File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.9/site-packages/urllib3/util/retry.py", line 574, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='rx-a740-b58dc70', port=80): Max retries exceeded with url: /YamahaRemoteControl/desc.xml (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f9e561df0>: Failed to establish a new connection: [Errno -3] Try again'))
File "/usr/local/lib/python3.9/site-packages/rxv/rxv.py", line 137, in _discover_features
desc_xml = self._session.get(
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 555, in get
return self.request('GET', url, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='rx-a740-b58dc70', port=80): Max retries exceeded with url: /YamahaRemoteControl/desc.xml (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f9e561df0>: Failed to establish a new connection: [Errno -3] Try again'))
2021-11-09 23:38:25 ERROR (MainThread) [homeassistant.components.media_player] Error while setting up yamaha platform for media_player
self.send(msg)
self.connect()
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 249, in _async_setup_platform
await asyncio.shield(task)
File "/usr/src/homeassistant/homeassistant/components/yamaha/media_player.py", line 152, in async_setup_platform
receivers = await hass.async_add_executor_job(_discovery, config_info)
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/src/homeassistant/homeassistant/components/yamaha/media_player.py", line 136, in _discovery
receivers = rxv.RXV(config_info.ctrl_url, config_info.name).zone_controllers()
File "/usr/local/lib/python3.9/site-packages/rxv/rxv.py", line 132, in __init__
self._discover_features()
