I am trying to add appdaemon to my existing HA setup that is started/stopped by docker-compose.
Here is the docker-compose.yaml I am trying to get to work:
version: "2"
services:
home-assistant:
#image: homeassistant/home-assistant:0.99.3
image: homeassistant/home-assistant:0.104.2
container_name: homeassistant
environment:
- TZ=Europe/Berlin
volumes:
- ${HA}:/config
restart: unless-stopped
network_mode: host
appdaemon:
container_name: appdaemon
image: appdaemon:latest
environment:
- HA_URL="http://127.0.0.1:8123"
- HA_KEY="eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJkMmQzZjU3NTA0ZWI0YTE0YWVhM2VlMzIyOTgzYjIyYSIsImlhdCI6MTU3OTQ0MzU0MywiZXhwIjoxODk0ODAzNTQzfQ.2Gbcl2j-X_UBGGr7-7St9ghHqaS3FIUn0Hw_SGuKZbe"
ports:
- 5050:5050
volumes:
- ${AD}/config:/conf
depends_on:
- home-assistant
network_mode: host
restart: on-failure:15
networks:
default:
external:
I have removed a nodered and an mqtt container from the file so that it is easier to read, let me know if I should readd them.
The containers share a network with an nginx-container (started in another compose file) that takes care of ssl-redirection for me.
Now to the problem: Every time I start the container appdaemon exits with
appdaemon | 2020-01-20 22:21:18.703417 INFO AppDaemon: AppDaemon Version 4.0.1 starting
appdaemon | 2020-01-20 22:21:18.703886 INFO AppDaemon: Python version is 3.8.1
appdaemon | 2020-01-20 22:21:18.704449 INFO AppDaemon: Configuration read from: /conf/appdaemon.yaml
appdaemon | 2020-01-20 22:21:18.705246 INFO AppDaemon: Added log: AppDaemon
appdaemon | 2020-01-20 22:21:18.705752 INFO AppDaemon: Added log: Error
appdaemon | 2020-01-20 22:21:18.706200 INFO AppDaemon: Added log: Access
appdaemon | 2020-01-20 22:21:18.706978 INFO AppDaemon: Added log: Diag
appdaemon | 2020-01-20 22:21:18.707517 ERROR AppDaemon: time_zone not specified in appdaemon.cfg
appdaemon | 2020-01-20 22:21:18.708047 ERROR AppDaemon: latitude not specified in appdaemon.cfg
appdaemon | 2020-01-20 22:21:18.708551 ERROR AppDaemon: longitude not specified in appdaemon.cfg
appdaemon | 2020-01-20 22:21:18.709395 ERROR AppDaemon: elevation not specified in appdaemon.cfg
Which I think means it can’t connect to home assistant. I checked the token 5 times (using curl), it is absolutely correct.
How can I make appdaemon connect to HA? I tried changing HA_URL to 127.0.0.1, localhost and the actual IP address of the raspberry pi I am running this on.
Here is my appdaemon.yaml:
appdaemon:
plugins:
HASS:
type: hass
ha_url: "http://127.0.0.1:8123"
token: eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJkMmQzZjU3NTA0ZWI0YTE0YWVhM2VlMzIyOTgzYjIyYSIsImlhdCI6MTU3OTQ0MzU0MywiZXhwIjoxODk0ODAzNTQzfQ.2Gbcl2j-X_UBGGr7-7St9ghHqaS3FIUn0Hw_SGuKZbe
http:
url: http://raspberrypi:5050
admin:
api:
hadashboard:
I don’t know whether it’s important, as far as I understood the environment variables take precedence.
Any help is appreaciated! Thanks!
