Hi there,
I have setup my home with a solar panels system with a SolarEdge inverter WaveHD 6KVA.
Everything works fine thanks to the HACS https://github.com/binsentsu/home-assistant-solaredge-modbus component.
Now I want to add to my system a battery.
1/ A direct solution would be to add a supported SolarEdge battery, by DC coupling.
- LGChem High voltage batterie
- BYD High voltage batterie
- 48V SolarEDge
All of those limited but supported batteries a good but expensive
2/ Another solution is to have a independent solution with a system (battery + inverter / loader), by a AC coupling.
This is an independent solution, you can select the best cost/efficient batterie, but you need to have an extra inverter/loader in addition to the SolarEdge one. Sync of both inverter will be done by home assistant.
- You have to pay 2 times an inverter/loader.
- You have power lost when going from PV-DC to AC then to DC-Battery.
Q1/ Does anyone has a better solution that 2/ ?
- by at least connecting the PV-DC with the PV-Battery (with maybe a MPPT)
- or by using the SolarEdge inverter only, why the solarEdge inverter need to know that is a battery ? if you control the battery from HomeAssistant to tell him that you need to provide x kw ?
Thanks a lot in advance
