Hallo all
I have this problem where I’m grateful for help:
I want to learn Homeatic Components to Home Asisstant.
Therefore I use homatic-manager (V2.5).
After starting the homematic-manager (hman), no connection to home assistant seems to be established. I assume this because I would expect a green tick at the top right of the IP address.
I use RPI 3B, RPI-RF-MOD of ELV as hardware and the add-on HomeMatic OCCU.
Does anybody has an Idea or clue how to get connection established?
Trouble shooting I tried so far but did not solve problem:
Switched off Windows firewall
Rebooted Hardware, server and main system (settings area of home assistant)
Power-Off-On
Some basic system information:
home assistant:
System HassOS 2.11
Deployment: production
home assistant supervisor 157
Add-on was up and running: puzzle in home assistant add-on overview is green.
Add-on:
"rf_enable": true,
"rf": [
"type": "CCU2",
"device": "/dev/ttyAMA0"
"wired_enable": false,
"wired": [
"serial": "xy",
"key": "abc",
"ip": "192.168.0.0"
"hmip_enable": false,
"hmip": [
"type": "HMIP_CCU2",
"device": "/dev/ttyUSB0"
Network:
configuration.yaml
homematic:
interfaces:
rf:
host: core-homematic
port: 2000
wired:
port: 2001
hmip:
` port: 2010`
Hardware
- serial:
- /dev/ttyS0
- /dev/ttyAMA0
- input:
- disk:
- gpio:
- gpiochip100
- gpio18
- gpiochip0
- gpiochip128
- audio:
- 0:
- name: bcm2835_alsa - bcm2835 ALSA
- type: ALSA
- devices:
- [object Object]
- [object Object]
- 0:
If analysis data is still missing here (e.g. log messages), then I am willing to deliver it, would appreciate a hint what to do.
Thanks in advance,
Jens
