How to connect Llama.cpp server to Home Assistant?
Hi, I was able to get Ollama to connect to home assistant to serve a local LLM, but I’ve moved to using more llama.cpp for fine grain control. However, when I go to try to connect things together again, I haven’t found a way to connect a home assistant to my local llama server.
Has anyone been able to get to work? I see a thread that seems to use a specific llama.cpp python docker container. Was wondering if there is a way by just linking into the the llama-server? I’m able to get open webui to connect that way via a local lan ip address and port, but have tried using extended openai and custom conversations without any success…
Any help is appreciated!
I was able to connect using the Custom Conversation integration, selecting OpenAI an using the llama.cpp server address: http://llamaserverip:8080/v1 and anything for Api key
Is this still the best integration methodology?
Why not use LM Studio as the frontend for Llama.cpp? Then you would use extended open conversation from HACS.
This hacs intergration Local OpenAI LLM, GitHub - skye-harris/hass_local_openai_llm: Home Assistant LLM integration for local OpenAI-compatible services (llamacpp, vllm, etc) · GitHub, function great with llama.cpp and home assistant.
The same author har made the integration, Tools for Assist GitHub - skye-harris/llm_intents: Exposes internet search tools for use by LLM-backed Assist in Home Assistant · GitHub, which gives
Additional tools for LLM-backed Assist for Home Assistant:
  • Web Search powered by your choice of Brave or SearXNG
  • Location Search powered by Google Places
  • Wikipedia
  • Weather Forecast
  • YouTube Search and Playback
I’m also using Local OpenAI LLM now and it works really well as it works as the native integration with better support for vision, structured output, AI Tasks.
@haraldov, I didn’t know about the Tools for Assist, thanks for sharing, I will definitely try it.
