How to connect MOES temperature and humidity zigbee sensor ZSS-X-TH-C
Device itself:
Looks like it’s not supported by zigbee2mqtt yet:
https://www.zigbee2mqtt.io/supported-devices/#v=Moes&s=zss
In the same time Moes Temperature And Humidity Sensor RH3052 Zigbee compatibility saying that it should work with zigbee2mqtt
Confusing.
Is there a way to connect it?
Looks like there are other ZSS temperature-humidity sensor?
Can I use it somehow?
I did manage to make it work.
In the zigbee2mqtt settings there are flag “allow join”.
Then it was able to find and recognize the device.
I cant even figure how out to turn the Moe’s on!!!
You can open the casing with coin or screwdriver.
there are small button you can press. Keep it pressed for 10 seconds or so and it will go to pairing mode.
