HA newbie here. Just got a cheap door sensor from monoprice so I can turn off the thermostat if the door is open.
I’m having issues getting HA to see the sensor. I use the tuya app/service for an outlet and a wall switch with no issue, but the sensor won’t show up in my entity list.
From other threads, I understand that tuya can be set up with a cloud config or locally if you have the device id/key. I’m using the cloud config. I’ve tried restarting the server multiple times and even removing the tuya section from the configuration.yaml and then replacing it… no good.
Here’s my config.
tuya: username: MYUSERNAME password: MYPASSWORD country_code: 1
Has anyone else has this issue? Is there something else I should try?
