Hi guys, I just installed the Sonoff mini r4m with some lights but I don’t know how to connect it to HomeAssistant via LAN without going through the cloud. Should I change firmware or not? To connect it via Matter do I have to install something on HomeAssistat? I read that Matter over WIFI devices must connect in IPv6, so should I enable DHCP in IPv6 on the pfSense?
Hey, newbie here. I am looking at Sonoff R4 Matter. Did you solve this? I am trying to decide between Shelly over WLAN, Sonoff with Zigbee or Sonoff with Matter.
I just replaced a ZBMINI with this MINIR4M.
I’m not impressed. The response time and the status reporting is significant slower than what I had with the old zigbee switch.
The switch was installed pretty close to an AP, so wifi signal is not the issue.
