How to connect the homeassistant mobile app in Google store to the homeassistant in raspberry pie
You input the URL for your Home Assistant server in the app.
输入Home Assistant服务器的URL
I’m sorry, but you’re going to need to use English here.
When you open the app, it will probably fail to find your Home Assistant server. Just manually type in the URL for it. If you are using a publicly accessible Home Assistant, like https://mydomain.duckdns.org or whatever you are using.
I try to enter the address of the homeassistant server 192.168.1.100:8123 or display an error
It’s settled thank you very much
Have you checked your configuration.yaml file? Does it contain ‘mobile_app:’ ?
thank you very much
