How to connect to Home Assistant locally after setup duckdns
Hi, I have setup DuckDNS and configure the yaml file. But, i found that i can’t do port forwarding in router due to ISP problem. Now, i want to connect to Home Assistant locally, but fail to login anymore. Please advise.
Can you SSH to your Home Assistant instances?
Try:
https://192.168.68.25:8123
You probably get an authenticity error, but it should open nevertheless….
(won’t work on phone though)
Better would be to define you duckdns domain within you router, so your duck dns name would resolve into 192.168.68.25 :wink:
Provided you can change your local domain name within your router :thinking:
