I am using docker compose for my homeassistant and mysql container:
networks:
internal:
driver: bridge
services:
ha-test:
image: ghcr.io/home-assistant/home-assistant:stable
container_name: ha-test
restart: unless-stopped
networks:
- internal
environment:
- TZ=Europe/Berlin
volumes:
- ${CONFIG_PATH}/ha-test:/config
- /run/dbus:/run/dbus:ro
ports:
- 7123:8123
db:
image: mysql:latest
container_name: mysql
networks:
- internal
environment:
- MYSQL_ROOT_PASSWORD=${ROOT_PASS}
- MYSQL_DATABASE=homeassistant
- MYSQL_USER=ha
- MYSQL_PASSWORD=changeme
I also tried using the entrypoint to create the database:
entrypoint:
sh -c "
echo 'CREATE DATABASE IF NOT EXISTS homeassistant; \
CREATE USER IF NOT EXISTS 'ha'@'%' IDENTIFIED BY 'changeme'; \
GRANT ALL PRIVILEGES ON homeassistant.* TO 'ha'@'%'; \
FLUSH PRIVILEGES;' > /docker-entrypoint-initdb.d/init.sql;
/usr/local/bin/docker-entrypoint.sh --character-set-server=utf8mb4 --collation-server=utf8mb4_unicode_ci
My configuration.yaml
looks like:
recorder:
db_url: mysql://ha:changeme@mysql/homeassistant?charset=utf8mb4
Still when starting homeassistant the logs always show:
sqlalchemy.exc.OperationalError: (MySQLdb.OperationalError) (1045, "Access denied for user 'ha'@'172.18.0.3' (using password: YES)")
(Background on this error at: https://sqlalche.me/e/20/e3q8)
I am able to log in into the database from inside the mysql container.
What am I doing wrong?
Thanks in advance.
