I’ve been working hard to get a NIBE heat pump to display it’s data in HA, and this has been a bit of a journey, so I thought I’d share my setup here in case other users would like to get their up and running.
First thing to mention, there is a Nibe integration for HA which interacts with the Nibe cloud platform v1. This has been superceded by a new (and not terribly much improved) cloud API for Nibe such that new heat pumps don’t work with this integration. But TBH, I’m not really sure why one would want to bother with that integration in the first place as this can all be accomplished in an entirely local, zero-cloud, modbus setup.
First things first, enable modbus over tcp on your Nibe control unit. I’ve got the NIBE SMO S40 (UK) control unit. You can enable modbus in menu 7.5.9 - simply change the setting to “on” and your control unit will communicate modbus via the configured internet connection. I’m assuming that you have already connected up the SMOS40 with an internet configuration. Mine is using ethernet with an address set up via DHCP (this can be found in menu 5.2.2).
Next, you need to add entries to configuration.yml - here’s how I have mine set up:
modbus:
- name: Nibe
type: tcp
host: 192.168.1.xxx # put in your server ip address here
port: 502
sensors:
- name: nibe_smos40_bt1
friendly_name: "BT1: Outdoor Temperature"
unit_of_measurement: °C
data_type: int16
device_class: temperature
address: 1
input_type: input
scale: 0.1
precision: 1
state_class: measurement
slave: 1
- name: nibe_smos40_bt7
friendly_name: "BT7: Hot Water Top"
data_type: int16
input_type: input
scale: 0.1
precision: 1
address: 8
slave: 1
- name: nibe_smos40_bt6
friendly_name: "BT6: Hot Water Charging"
address: 9
slave: 1
data_type: int16
input_type: input
scale: 0.1
precision: 1
- name: nibe_f2040_bt3
friendly_name: "BT3: Heating medium return line temp"
slave: 1
address: 1475
data_type: int16
input_type: input
scale: 0.1
precision: 1
- name: nibe_f2040_bt14
friendly_name: "BT14: Hot gas discharge temp"
slave: 1
address: 1479
data_type: int16
input_type: input
scale: 0.1
precision: 1
- name: nibe_f2040_bt15
friendly_name: "BT15: Condenser fluid pipe"
slave: 1
address: 1480
data_type: int16
input_type: input
scale: 0.1
precision: 1
- name: nibe_f2040_bt17
friendly_name: "BT17: Suction Gas"
slave: 1
address: 1481
data_type: int16
input_type: input
scale: 0.1
precision: 1
- name: nibe_f2040_bt12
friendly_name: "BT12: Condenser supply line temp"
slave: 1
address: 1478
data_type: int16
input_type: input
scale: 0.1
precision: 1
- name: nibe_f2040_bt28
friendly_name: "BT28: Outdoor ambient temp"
slave: 1
address: 1621
data_type: int16
input_type: input
scale: 0.1
precision: 1
- name: nibe_smos40_bt50
friendly_name: "Room temperature"
slave: 1
address: 26
data_type: int16
input_type: input
scale: 0.1
precision: 1
- name: nibe_smos40_bt25
friendly_name: "BT25: External supply line temp"
slave: 1
address: 39
data_type: int16
input_type: input
scale: 0.1
precision: 1
- name: nibe_f2040_bt16
friendly_name: "BT16a: Evaporator"
slave: 1
address: 1622
data_type: int16
input_type: input
scale: 0.1
precision: 1
- name: nibe_f2040_bt16_2
friendly_name: "BT16b: Evaporator"
slave: 1
address: 1966
data_type: int16
input_type: input
scale: 0.1
precision: 1
- name: nibe_smos40_bt71
friendly_name: "BT71: Return temperature"
slave: 1
address: 88
data_type: int16
input_type: input
scale: 0.1
precision: 1
- name: nibe_f2040_bp4
friendly_name: "BP4: Pressure"
unit_of_measurement: bar
slave: 1
address: 1801
input_type: input
scale: 0.1
precision: 1
- name: nibe_f2040_bp2
friendly_name: "BP2: Low pressure switch"
slave: 1
address: 1802
input_type: input
scale: 0.1
precision: 1
- name: nibe_f2040_ep14_total_time
friendly_name: "Compressor total run time"
unit_of_measurement: hours
slave: 1
address: 1491
- name: nibe_f2040_compressor_freq
friendly_name: "Compressor current frequency"
unit_of_measurement: hz
slave: 1
address: 1803
- name: nibe_smos40_eb100-gp12
friendly_name: "Charge Pump (EB100-GP12)"
slave: 1
address: 1636
unit_of_measurement: Percent
data_type: int16
device_class: power_factor
input_type: input
scale: 1
precision: 1
- name: nibe_smos40_supply_temp_min
slave: 1
address: 34
data_type: int16
scale: 0.1
precision: 1
- name: nibe_smos40_supply_temp_max
slave: 1
address: 38
data_type: int16
scale: 0.1
precision: 1
- name: nibe_smos40_prioritisation
friendly_name: "Operating prioritisation 1-off, 2-hot water 3- heat"
slave: 1
address: 1028
- name: nibe_smos40_alarm
slave: 1
address: 1975
- name: nibe_smos40_hot_water_demand
friendly_name: "Hot Water Demand (Sm/Md/Lg/Smart)"
slave: 1
address: 56
scan_interval: 60
- name: nibe_smos40_bt70_outgoing_hot_water
slave: 1
address: 87
data_type: int16
input_type: input
scale: 0.1
precision: 1
- name: nibe_smos40_degree_minutes
slave: 1
address: 18
- name: nibe_smos40_degree_minutes_cooling
slave: 1
address: 20
- name: nibe_smos40_reset_alarm
slave: 1
address: 22
- name: nibe_smos40_heating_curve
slave: 1
address: 26
- name: nibe_smos40_offset_curve
slave: 1
address: 30
- name: nibe_smos40_flow_sensor
unit_of_measurement: "l/m"
slave: 1
address: 40
scan_interval: 60
- name: nibe_smos40_current_be3
slave: 1
address: 46
- name: nibe_smos40_current_be2
slave: 1
address: 48
- name: nibe_smos40_current_be1
slave: 1
address: 50
- name: nibe_smos40_degree_minutes_start_additional_heat
slave: 1
address: 97
- name: nibe_smos40_degree_minutes_start_compressor
slave: 1
address: 159
- name: nibe_smos40_alarm_action_lower_room_temp
slave: 1
address: 196
- name: nibe_smos40_alarm_action_lower_hw_temp
slave: 1
address: 197
- name: nibe_smos40_operating_mode
slave: 1
address: 237
- name: nibe_smos40_pulse_energy_meter_be7
unit_of_measurement: kWh
slave: 1
address: 396
- name: nibe_smos40_pulse_energy_meter_be6
slave: 1
address: 398
- name: nibe_smos40_calculated_supply_temp
friendly_name: "Calculated supply temp"
slave: 1
address: 1017
data_type: int16
input_type: input
scale: 0.1
precision: 1
Voila, once you’ve restarted HA core, you should have a suite of sensors. I tend to have mine in a few different panels, “heat pump” “water tank” and then more niche stats in " Heat Pump - Refridgerant Circuit" and “Heat Pump - Heat Medium Circuit”. I’ve found the Nibe installers manuals to be pretty useful in terms of identifying where the various sensors fit and what they do for the heat pump. Here’s an annotated version I made for my own use:
and another more generic diagram (also annotated with sensors):
Good luck getting yours up online!
(I’m new to mqtt stuff)
