How to: Connecting the Homey Energy Dongle to Home Assistant with ESPHome
Hi everyone!
Recently my company launched the Homey Energy Dongle — a P1 to Wi-Fi device made specifically for Homey Cloud & Homey Pro.
Screenshot 2025-04-17 at 16.10.48
While of course it’s primarily designed to provide a seamless experience for Homey users, the hardware can be re-flashed with ESPHome for an all-local experience.
I’m writing this how-to for those who enjoy buying well-designed & well-tested hardware by an established brand, but prefer to use it with their own software.
The Homey Energy Dongle has a USB-C port, that when connected to a PC or Mac, you can use to flash ESPHome from a web browser.
Then, use this config:
esphome:
  friendly_name: Homey Energy Dongle
  on_boot:
    - priority: -100.0
      then:
        - output.turn_on: p1_input_enable
        - light.turn_on:
            red: 0%
            green: 0%
            blue: 100%
esp32:
  board: esp32-c6-devkitc-1
  flash_size: 4MB
  variant: esp32c6
  framework:
    type: esp-idf
    version: 5.3.1
    platform_version: 6.9.0
    sdkconfig_options:
      CONFIG_ESPTOOLPY_FLASHSIZE_4MB: y
ota:
  - platform: esphome
    password: "..." # Your OTA Password
wifi:
  ssid: !secret wifi_ssid
external_components:
  - source: github://oxan/esphome-stream-server
stream_server:
  - uart_id: p1_input
    port: 1234
    buffer_size: 256
uart:
  - id: p1_input
    rx_buffer_size: 256
    rx_pin:
      number: GPIO4
      inverted: true # You might need to flip this to `false` for some meters
    baud_rate: 115200 # Change this to 9600 for DSMR v2 meters.
  - id: p1_output
    tx_pin:
      number: GPIO3
      inverted: true
    baud_rate: 115200
output:
  - id: p1_input_enable
    platform: gpio
    pin:
      number: GPIO23
      mode: output
light:
  - id: led
    platform: esp32_rmt_led_strip
    rgb_order: GRB
    pin: GPIO2
    num_leds: 1
    chipset: ws2812
This will let the Homey Energy Dongle create a TCP server on port 1234. Every DSMR telegram will be broadcasted to all clients. You can test this with e.g. nc 192.168.0.100 1234 in a console on macOS.
Then, to import the data into Home Assistant, add the DSMR Smart Meter integration, and enter your device’s IP with port 1234. And your smart meter data, such as live usage (W), consumed electricity (kWh) and gas usage (m3) should appear inside Home Assistant.
Happy hacking! ^.^
Notes
  1. To revert back to the original firmware, visit usb.homey.app.
  2. I haven’t managed to get DSMR Passthrough working yet. I’m not very experienced with ESPHome, so maybe some wizard can take a look.
  3. When returning your product to a store, please factory reset using usb.homey.app. We really don’t want frustrated customers why their ‘Second Chance’ product doesn’t work with Homey.
  4. The reason the ESPHome DSMR component isn’t used, is because it requires the Arduino framework. However, the Arduino framework does not yet work with the newest ESP32-C6.
Hi @Emile_Athom and thanks for the open discussion - it’s great to see such transparency and flexibility with the Homey Energy Dongle!
As a user, I always want to get as more as possible from devices I own.
Quick question: does this openness also mean we could use the dongle with ESPHome to read M-Bus data from a Landis+Gyr E450 meter? Since that model isn’t natively supported in Homey, I’m curious if the stream server setup might work with a suitable ESPHome config, or if additional hardware or firmware support would be required.
Appreciate any thoughts or insights!
Hi @Emile_Athom,
Thanks for that info.
I have just activated my HomeAssistant Green so I am very fresh to HomeAssistant and ESP devices.
Trying to follow your instructions in order to connect the Homey dongle.
I connected to the dongle using web.ESPhome.io (in Chrome), after I clicked 'Prepare for first use’, it first reports ‘Configuration installed’ but then when it tries to connect I get ‘An error occurred. Improv Wi-Fi Serial not detected’.
I tried several usb cables here including one for an usb drive (which should be able to handle both power and data)
Should I be taking others steps first or take a different route to flashing the dongle?
Thanks,
Pascal
Hey Pascal! You need to press the reset button located next to the USB-C connection with a sim ejection tool or similar while connecting the cable. That will put the device in a state where it’s ready to be flashed with new firmware. Note that the LED indicator won’t turn on.
I did manage to flash the dongle with ESPHome, but haven’t yet been able to connect it with DSMR Smart Meter.
Has anyone gotten this to work? I’m searching for good quality P1 electricity dongles, having bad luck with smartgateway ones.
I actually got mine running. My issue was that I had to activate the P1 port on my meter. Once it was activated my flashed Homey Energy Dongle started feeding the Home Assistant DSMR plugin.
Nice! Choosing between this and one of the ”slimmelezer” someone is selling. https://www.zuidwijk.com/product-category/webshop/
Did a quick write-up here on how I got it running at home: Homey Energy Dongle with Home Assistant
Thanks for this!
Does the DSMR component now work on c6? Arduino framework now supports c6. Also, does the output work?
For whom it may concern, here a config that works in Sweden, using a PR for a esp-idf based ESPHome dsmr component
esphome:
  friendly_name: Energy Dongle
  on_boot:
    - priority: -100.0
      then:
        - light.turn_on:
            red: 0%
            green: 0%
            blue: 20%
esp32:
  flash_size: 4MB
  variant: esp32c6
  framework:
    type: esp-idf
    sdkconfig_options:
wifi:
api:
logger:
uart:
  - id: uart_dsmr
    rx_buffer_size: 4096
    rx_pin:
      number: GPIO4
      inverted: true
    baud_rate: 115200
dsmr:
  uart_id: uart_dsmr
  crc_check: true
  - source: github://pr#11036
    components: [dsmr]
    refresh: 1h
  - platform: dsmr
    energy_delivered_lux:
      name: "Accumulated active import"
    energy_returned_lux:
      name: "Accumulated active export"
    # active power (total)
    power_returned:
    power_delivered:
    # per-phase active power
    power_delivered_l1:
      name: "L1 active import"
    power_delivered_l2:
      name: "L2 active import"
    power_delivered_l3:
      name: "L3 active import"
    power_returned_l1:
      name: "L1 active export"
    power_returned_l2:
      name: "L2 active export"
    power_returned_l3:
      name: "L3 active export"
    # reactive power
    reactive_power_delivered:
    reactive_power_returned:
    # per-phase reactive power
    reactive_power_delivered_l1:
      name: "L1 reactive import"
    reactive_power_delivered_l2:
      name: "L2 reactive import"
    reactive_power_delivered_l3:
      name: "L3 reactive import"
    reactive_power_returned_l1:
      name: "L1 reactive export"
    reactive_power_returned_l2:
      name: "L2 reactive export"
    reactive_power_returned_l3:
      name: "L3 reactive export"
    # voltages
    voltage_l1:
    voltage_l2:
    voltage_l3:
    # currents
    current_l1:
    current_l2:
    current_l3:
text_sensor:
  - platform: dsmr
    timestamp:
      name: "Meter timestamp"
    identification:
    telegram:
      name: "Raw DSMR Telegram"
      internal: true
  - platform: version
    hide_timestamp: true
light:
  - id: led
    rgb_order: GRB
    pin: GPIO2
    num_leds: 1
    chipset: ws2812%
Thak you for your write-up. I have done many attempts with 2 different cables, both on my macbook with google chrome as directly connected to the home assistant green.
In the best case “preparing installation” keeps on spinning after this sequence: “+new device > jtag/serial debug unit > connect > connecting > preparing installation”
Do you have an idea what is going wrong?
Also when I click skip initially to be able to select “ESP32-C6”. Also when following this step the ESPhome creates a device but it is offline. I can click edit, add the code, click save and install. Connecting spins and then continues to preparing installation but then hangs.
Grymt. Why don’t the original file not work in Sweden?
I have managed to set it up, however when I try to connect to it with the right ip and port 1234 and DSRM-version 5 I get cant connect. “det gick inte att ansluta”. Did you get this error too?
Also I see that you don’t assign the port 1234 in your file?
Tja!
I vaguely remember that the original config from @Emile_Athom did not work for me either, but the slightly modified version from @r8805 in worked.
Anyhow, this approach is now less relevant as these two configs are using an external component that streams the data on a specific port. My config is using the esphome native dmsr component. Previously this was not possible as it was as it was built on top of the Arduino framework which did not support esp32-c6. In the 2026.1.0 release of esphome, the dsmr component is now migrated over to esp-idf.
My config should be modified from of 2026.1.0 as following, however, I have not yet had the time to try.
esphome:
  on_boot:
    - priority: -100.0
      then:
        - light.turn_on:
            red: 0%
            green: 0%
            blue: 20%
esp32:
  flash_size: 4MB
  variant: esp32c6
  framework:
    type: esp-idf
    sdkconfig_options:
wifi:
api:
logger:
uart:
  - id: uart_dsmr
    rx_pin:
      number: GPIO4
      inverted: true
    baud_rate: 115200
dsmr:
  uart_id: uart_dsmr
  crc_check: true
#external_components:
#  - source: github://pr#11036
#    components: [dsmr]
#    refresh: 1h
  - platform: dsmr
    power_returned:
    power_delivered:
    power_delivered_l1:
    power_delivered_l2:
    power_delivered_l3:
    power_returned_l1:
    power_returned_l2:
    power_returned_l3:
    # reactive power
    # voltages
    voltage_l1:
    voltage_l2:
    voltage_l3:
    # currents
    current_l1:
    current_l2:
    current_l3:
text_sensor:
  - platform: dsmr
    timestamp:
    identification:
    telegram:
      internal: true
  - platform: version
light:
  - id: led
    rgb_order: GRB
    pin: GPIO2
    num_leds: 1
    chipset: ws2812%
same here @kfarbridges-ha . Did you eventually find a solution to the spining Preparing Installation?
TX is on GPIO5 non-inverted
You can’t use both (telnet and TX), that’s a limitation of ESPHome.
GPIO22 is high when no dongle connected and becomes low when data is requested
Hi guys,
So I am completely lost here.
I have a Homey dongle, it working fine.
I decided I want to add it to home assistant.
What I get so for:
I flash it on Web - ESPHome.
I can prepare for first use. Installs fine, set up wifi with no issues.
[14:35:41][I][wifi:1149]: Connected
[14:35:41][C][wifi:897]:   Local MAC: 90:13:DA:77:6F:06
[14:35:41][C][wifi:904]:   IP Address: 192.168.2.42
[14:35:41][C][wifi:908]:   SSID: [redacted]
[14:35:41][C][wifi:908]:  BSSID: [redacted]
[14:35:41][C][wifi:908]:  Hostname: 'esphome-web-776f06'
[14:35:41][C][wifi:908]:  Signal strength: -49 dB ▂▄▆█
[14:35:41][C][wifi:908]:  Channel: 11
[14:35:41][C][wifi:908]:  Subnet: 255.255.255.0
[14:35:41][C][wifi:908]:  Gateway: 192.168.2.1
[14:35:41][C][wifi:908]:  DNS1: 62.179.104.196
[14:35:41][C][wifi:908]:  DNS2: 213.46.228.196
[14:35:41][D][wifi:1173]: Disabling AP
[14:35:41][W][component:373]: wifi cleared Warning flag
I make a new device in ESPHome builder.
Push the pin, and connect directly to USB on HA server.
Install homey-dongle.yaml
INFO ESPHome 2026.2.4
INFO Reading configuration /config/esphome/homey-dongle.yaml...
INFO Generating C++ source...
INFO Setting CONFIG_LWIP_MAX_SOCKETS to 11 (registered: api=4, captive_portal=4, mdns=2, ota=1)
INFO Compiling app... Build path: /data/build/homey-dongle
Processing homey-dongle (board: esp32-c6-devkitc-1; framework: espidf; platform: https://github.com/pioarduino/platform-espressif32/releases/download/55.03.37/platform-espressif32.zip)
Library Manager: Installing esphome/noise-c @ 0.1.10
INFO Installing esphome/noise-c @ 0.1.10
Unpacking  [####################################]  100%
Library Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
Library Manager: Installing esphome/libsodium @ 1.10020.7
INFO Installing esphome/libsodium @ 1.10020.7
HARDWARE: ESP32C6 160MHz, 320KB RAM, 4MB Flash
 - contrib-piohome @ 3.4.4
 - framework-espidf @ 3.50502.0 (5.5.2)
 - tool-cmake @ 4.0.3
 - tool-esp-rom-elfs @ 2024.10.11
 - tool-esptoolpy @ 5.1.2
 - tool-ninja @ 1.13.1
 - tool-scons @ 4.40801.0 (4.8.1)
 - toolchain-riscv32-esp @ 14.2.0+20251107
Reading CMake configuration...
Generating assembly for certificate bundle...
Dependency Graph
======================== [SUCCESS] Took 520.98 seconds ========================
INFO Build Info: config_hash=0xc91d1c68 build_time_str=2026-03-14 14:41:05 +0100
INFO Successfully compiled program.
esptool v5.1.0
Serial port /dev/ttyACM0:
Connecting...
Connected to ESP32-C6 on /dev/ttyACM0:
Chip type:          ESP32-C6FH4 (QFN32) (revision v0.1)
Features:           Wi-Fi 6, BT 5 (LE), IEEE802.15.4, Single Core + LP Core, 160MHz
Crystal frequency:  40MHz
USB mode:           USB-Serial/JTAG
MAC:                e4:b3:23:ff:fe:99:f2:1c
BASE MAC:           e4:b3:23:99:f2:1c
MAC_EXT:            ff:fe
Uploading stub flasher...
Running stub flasher...
Stub flasher running.
Changing baud rate to 460800...
Changed.
Configuring flash size...
Auto-detected flash size: 4MB
Flash will be erased from 0x00010000 to 0x000fbfff...
Flash will be erased from 0x00000000 to 0x00005fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x00009000 to 0x0000afff...
Compressed 965984 bytes to 616092...
Writing at 0x00010000 [                              ]   0.0% 0/616092 bytes...
Writing at 0x0001bffc [                              ]   2.7% 16384/616092 bytes...
Writing at 0x00024cdc [>                             ]   5.3% 32768/616092 bytes...
Writing at 0x00029307 [=>                            ]   8.0% 49152/616092 bytes...
Writing at 0x00030302 [==>                           ]  10.6% 65536/616092 bytes...
Writing at 0x00037401 [==>                           ]  13.3% 81920/616092 bytes...
Writing at 0x0003d4ac [===>                          ]  16.0% 98304/616092 bytes...
Writing at 0x00042ea7 [====>                         ]  18.6% 114688/616092 bytes...
Writing at 0x00048e45 [=====>                        ]  21.3% 131072/616092 bytes...
Writing at 0x0004eb94 [======>                       ]  23.9% 147456/616092 bytes...
Writing at 0x00055039 [======>                       ]  26.6% 163840/616092 bytes...
Writing at 0x0005addd [=======>                      ]  29.3% 180224/616092 bytes...
Writing at 0x00060a48 [========>                     ]  31.9% 196608/616092 bytes...
Writing at 0x00066c6c [=========>                    ]  34.6% 212992/616092 bytes...
Writing at 0x0006d4de [==========>                   ]  37.2% 229376/616092 bytes...
Writing at 0x00073a21 [==========>                   ]  39.9% 245760/616092 bytes...
Writing at 0x00079b01 [===========>                  ]  42.5% 262144/616092 bytes...
Writing at 0x0007fff6 [============>                 ]  45.2% 278528/616092 bytes...
Writing at 0x00085f6b [=============>                ]  47.9% 294912/616092 bytes...
Writing at 0x0008bd82 [==============>               ]  50.5% 311296/616092 bytes...
Writing at 0x00091472 [==============>               ]  53.2% 327680/616092 bytes...
Writing at 0x00096e12 [===============>              ]  55.8% 344064/616092 bytes...
Writing at 0x0009c8be [================>             ]  58.5% 360448/616092 bytes...
Writing at 0x000a24ff [=================>            ]  61.2% 376832/616092 bytes...
Writing at 0x000a7f16 [==================>           ]  63.8% 393216/616092 bytes...
Writing at 0x000adf53 [==================>           ]  66.5% 409600/616092 bytes...
Writing at 0x000b3951 [===================>          ]  69.1% 425984/616092 bytes...
Writing at 0x000b9d7e [====================>         ]  71.8% 442368/616092 bytes...
Writing at 0x000c03fc [=====================>        ]  74.5% 458752/616092 bytes...
Writing at 0x000c6382 [======================>       ]  77.1% 475136/616092 bytes...
Writing at 0x000cc4a0 [======================>       ]  79.8% 491520/616092 bytes...
Writing at 0x000d2544 [=======================>      ]  82.4% 507904/616092 bytes...
Writing at 0x000d84e4 [========================>     ]  85.1% 524288/616092 bytes...
Writing at 0x000de4ea [=========================>    ]  87.8% 540672/616092 bytes...
Writing at 0x000e4304 [==========================>   ]  90.4% 557056/616092 bytes...
Writing at 0x000ea7bf [==========================>   ]  93.1% 573440/616092 bytes...
Writing at 0x000f0802 [===========================>  ]  95.7% 589824/616092 bytes...
Writing at 0x000f6686 [============================> ]  98.4% 606208/616092 bytes...
Writing at 0x000fbd60 [==============================] 100.0% 616092/616092 bytes...
Wrote 965984 bytes (616092 compressed) at 0x00010000 in 9.0 seconds (854.9 kbit/s).
Hash of data verified.
SHA digest in image updated.
Compressed 22720 bytes to 14031...
Writing at 0x00000000 [                              ]   0.0% 0/14031 bytes...
Writing at 0x000058c0 [==============================] 100.0% 14031/14031 bytes...
Wrote 22720 bytes (14031 compressed) at 0x00000000 in 0.5 seconds (401.4 kbit/s).
Compressed 3072 bytes to 134...
Writing at 0x00008000 [                              ]   0.0% 0/134 bytes...
Writing at 0x00008c00 [==============================] 100.0% 134/134 bytes...
Wrote 3072 bytes (134 compressed) at 0x00008000 in 0.0 seconds (532.5 kbit/s).
Compressed 8192 bytes to 31...
Writing at 0x00009000 [                              ]   0.0% 0/31 bytes...
Writing at 0x0000b000 [==============================] 100.0% 31/31 bytes...
Wrote 8192 bytes (31 compressed) at 0x00009000 in 0.1 seconds (702.6 kbit/s).
Hard resetting via RTS pin...
INFO Successfully uploaded program.
INFO Starting log output from /dev/ttyACM0 with baud rate 115200
This seems good.
I paste this code:
esphome:
  on_boot:
    - priority: -100.0
      then:
        - light.turn_on:
            red: 0%
            green: 100%  < this to know its actually uploaded
            blue: 0%
esp32:
  flash_size: 4MB
  variant: esp32c6
  framework:
    type: esp-idf
    sdkconfig_options:
ota:
  - platform: esphome
    password: "...." # <<< A random password for OTA
wifi:
stream_server:
  - uart_id: p1_input
    port: 1234
    buffer_size: 256
uart:
  - id: p1_input
    rx_buffer_size: 256
    rx_pin:
      number: GPIO4
      inverted: true
    baud_rate: 115200
  - id: p1_output
    tx_pin:
      number: GPIO3
      inverted: true
    baud_rate: 115200
output:
    platform: gpio
    pin:
      number: GPIO23
      mode: output
light:
  - id: led
    rgb_order: GRB
    pin: GPIO2
    num_leds: 1
    chipset: ws2812
With dongle still connected to server I install *(do I need to reconnect it with pin pushed?). With this outcome:
INFO Compiling app... Build path: /data/build/homey-energy-dongle
Processing homey-energy-dongle (board: esp32-c6-devkitc-1; framework: espidf; platform: https://github.com/pioarduino/platform-espressif32/releases/download/55.03.37/platform-espressif32.zip)
No dependencies
======================== [SUCCESS] Took 506.04 seconds ========================
INFO Build Info: config_hash=0xc76b1d76 build_time_str=2026-03-14 14:59:58 +0100
esptool v5.1.0
Connecting...
MAC_EXT:            ff:fe
Changed.
Flash will be erased from 0x00010000 to 0x000d5fff...
Compressed 810496 bytes to 505335...
Writing at 0x00010000 [                              ]   0.0% 0/505335 bytes...
Writing at 0x0001c63a [                              ]   3.2% 16384/505335 bytes...
Writing at 0x00025a0c [>                             ]   6.5% 32768/505335 bytes...
Writing at 0x0002c807 [=>                            ]   9.7% 49152/505335 bytes...
Writing at 0x0003284d [==>                           ]  13.0% 65536/505335 bytes...
Writing at 0x0003879a [===>                          ]  16.2% 81920/505335 bytes...
Writing at 0x0003e7a8 [====>                         ]  19.5% 98304/505335 bytes...
Writing at 0x00044450 [=====>                        ]  22.7% 114688/505335 bytes...
Writing at 0x0004b0a7 [======>                       ]  25.9% 131072/505335 bytes...
Writing at 0x00051963 [=======>                      ]  29.2% 147456/505335 bytes...
Writing at 0x00057c46 [========>                     ]  32.4% 163840/505335 bytes...
Writing at 0x0005e16c [=========>                    ]  35.7% 180224/505335 bytes...
Writing at 0x00064584 [==========>                   ]  38.9% 196608/505335 bytes...
Writing at 0x0006a2cb [===========>                  ]  42.1% 212992/505335 bytes...
Writing at 0x0006fb38 [============>                 ]  45.4% 229376/505335 bytes...
Writing at 0x000753f8 [=============>                ]  48.6% 245760/505335 bytes...
Writing at 0x0007b1ea [==============>               ]  51.9% 262144/505335 bytes...
Writing at 0x00080bde [===============>              ]  55.1% 278528/505335 bytes...
Writing at 0x000869ad [================>             ]  58.4% 294912/505335 bytes...
Writing at 0x0008c896 [=================>            ]  61.6% 311296/505335 bytes...
Writing at 0x00092f63 [==================>           ]  64.8% 327680/505335 bytes...
Writing at 0x00099005 [===================>          ]  68.1% 344064/505335 bytes...
Writing at 0x0009f04e [====================>         ]  71.3% 360448/505335 bytes...
Writing at 0x000a5137 [=====================>        ]  74.6% 376832/505335 bytes...
Writing at 0x000aae62 [======================>       ]  77.8% 393216/505335 bytes...
Writing at 0x000b1008 [=======================>      ]  81.1% 409600/505335 bytes...
Writing at 0x000b6d9e [========================>     ]  84.3% 425984/505335 bytes...
Writing at 0x000bd276 [=========================>    ]  87.5% 442368/505335 bytes...
Writing at 0x000c39f6 [==========================>   ]  90.8% 458752/505335 bytes...
Writing at 0x000c935c [===========================>  ]  94.0% 475136/505335 bytes...
Writing at 0x000cf0da [============================> ]  97.3% 491520/505335 bytes...
Writing at 0x000d5e00 [==============================] 100.0% 505335/505335 bytes...
Wrote 810496 bytes (505335 compressed) at 0x00010000 in 7.5 seconds (862.3 kbit/s).
Compressed 22720 bytes to 14037...
Writing at 0x00000000 [                              ]   0.0% 0/14037 bytes...
Writing at 0x000058c0 [==============================] 100.0% 14037/14037 bytes...
Wrote 22720 bytes (14037 compressed) at 0x00000000 in 0.4 seconds (405.3 kbit/s).
Wrote 3072 bytes (134 compressed) at 0x00008000 in 0.0 seconds (551.8 kbit/s).
Wrote 8192 bytes (31 compressed) at 0x00009000 in 0.1 seconds (701.7 kbit/s).
ERROR Logger is not configured!
After all this, I disconnect the dongle and reconnect it.
Lights up green.
ERROR All specified devices ['OTA'] could not be resolved. Is the device connected to the network? If you know the IP, set 'use_address' in your network config.
Logs homey-dongle.yaml
What can I do about the logger error?
I dont know what im doing wrong, can somebody help out?
Ok so dont ask me how. But with this code it is working now. Had to change some values in the light section.
Thanks for this code @msasdk
esphome:
  friendly_name: Homey Dongle v2
  on_boot:
    - priority: -100.0
      then:
        - light.turn_on:
            red: 100% (for confirmation of new code is actually loaded)
            green: 0%
            blue: 0%
esp32:
  flash_size: 4MB
  variant: esp32c6
  framework:
    type: esp-idf
    sdkconfig_options:
wifi:
api:
logger:
uart:
  - id: uart_dsmr
    rx_pin:
      number: GPIO4
      inverted: true
    baud_rate: 115200
dsmr:
  uart_id: uart_dsmr
  crc_check: true
#    refresh: 1h
  - platform: dsmr
    power_returned:
    power_delivered:
    power_delivered_l1:
    power_delivered_l2:
    power_delivered_l3:
    power_returned_l1:
    power_returned_l2:
    power_returned_l3:
    # reactive power
    # voltages
    voltage_l1:
    voltage_l2:
    voltage_l3:
    # currents
    current_l1:
    current_l2:
    current_l3:
text_sensor:
  - platform: dsmr
    timestamp:
    identification:
    telegram:
      internal: true
  - platform: version
light:
  - id: led
    rgb_order: GRB
    pin: GPIO2
    num_leds: 1
    chipset: ws2812
I use the “DSMR Smart Meter” integration together with the Homey Energy dongle, connected over usb, with the original firmware. It can be fiddly to get it working (it really got better in the months since I started using HA back in November ‘25), but when it works, it works very stable. The other thing that’s a bit of a hassle is that the integration can break down after an update, especially HAOS updates, Core updates are not a problem. It’s a matter of deleting the integration, unplugging/replugging the usb cable and adding the hub again. I live in the Netherlands btw, so DMSR V5 for me.
