I had a problem adding a BLE strip I have (see GitHub issue here). That bug/problem is until now not fix.
Since I really wanted to control that strip, I ended up creating a virtual light. Maybe this helps to another person on with the same problem.
This is the code I used:
esp32-board.ymal
substitutions:
bluetooth_virtual_light_mac: THE:LBE:MAC:HERE
packages:
bluetooth_virtual_light: !include common/bluetooth-virtual-light.yaml
esphome:
includes:
- common/bluetooth-virtual-light.h
binary_sensor:
name: "Led BLE Connected"
ble_client:
- mac_address: ${bluetooth_virtual_light_mac}
on_connect:
then:
- lambda: |-
ESP_LOGD("virtual_ble_light", "Connected to BLE device");
- binary_sensor.template.publish:
state: ON
- switch.turn_off: led_ble_on_off_switch
on_disconnect:
then:
- lambda: |-
ESP_LOGD("virtual_ble_light", "Disconnected to BLE device");
state: OFF
light:
- platform: rgb
red: red_channel_output
green: green_channel_output
blue: blue_channel_output
default_transition_length: 0.25s
on_state:
- lambda: |-
ESP_LOGD("virtual_ble_light", "State Send");
on_turn_on:
- lambda: |-
id(led_ble_on_off_switch).turn_on();
on_turn_off:
- lambda: |-
id(led_ble_on_off_switch).turn_off();
output:
type: float
min_power: 0.003
zero_means_zero: true
write_action:
- lambda: |-
SSDBluetoothVirtualLight::updateRed(state);
// char buf[30];
// sprintf(buf, "red_channel_output=%.6f", state);
// ESP_LOGI("virtual_ble_light", buf);
type: float
min_power: 0.003
write_action:
- lambda: |-
SSDBluetoothVirtualLight::updateGreen(state);
// char buf[30];
// sprintf(buf, "green_channel_output=%.6f", state);
type: float
min_power: 0.003
write_action:
- lambda: |-
SSDBluetoothVirtualLight::updateBlue(state);
// char buf[30];
// sprintf(buf, "blue_channel_output=%.6f", state);
- ble_client.ble_write:
service_uuid: FFE0
characteristic_uuid: FFE1
value: !lambda |-
return SSDBluetoothVirtualLight::getCreateColorUpdateArray();
switch:
- platform: ble_client
ble_client_id: led_strip_ble_client
name: "Enable Bluetooth"
internal: true
name: "Turn On Led"
internal: true
restore_mode: ALWAYS_OFF
turn_on_action:
service_uuid: FFE0
value: !lambda |-
return SSDBluetoothVirtualLight::turnOnArray;
turn_off_action:
service_uuid: FFE0
value: !lambda |-
return SSDBluetoothVirtualLight::turnOffArray;
- lambda: |-
ESP_LOGD(SSDBluetoothVirtualLight::logTag, "SEND MESSAGE TO TURN OFF");
// #include <esphome.h>
#include <vector>
namespace SSDBluetoothVirtualLight {
const char* logTag = "ssd_virtual_bluetooth_light";
const std::vector<uint8_t> turnOffArray = {126, 255, 4, 0, 255, 255, 255, 255, 239};
const std::vector<uint8_t> turnOnArray = {126, 255, 4, 1, 255, 255, 255, 255, 239};
const std::vector<uint8_t> noColorArray = {126, 255, 5, 3, 0, 0, 0, 255, 239};
float red = 0;
float green = 0;
float blue = 0;
std::vector<uint8_t> getCreateColorUpdateArray()
uint8_t convertedRed = static_cast<uint8_t>(red * 255);
uint8_t convertedGreen = static_cast<uint8_t>(green * 255);
uint8_t convertedBlue = static_cast<uint8_t>(blue * 255);
return {126, 255, 5, 3, convertedRed, convertedGreen, convertedBlue, 255, 239};
void updateRed(float value){
red = value;
void updateGreen(float value){
green = value;
void updateBlue(float value){
blue = value;
Enjoy!
