I want to make a dimmer switch using esphome to control the bulb (Yeelight).
I still don’t understand Analog To Digital Sensor. It shows about 0.02 to 3.2v
What should I do to get it to control the brightness?
This is my source code.
esphome:
esp32:
board: m5stack-atom
framework:
type: arduino
version: latest
ota:
password: !secret esphome_pass
logger:
api:
wifi:
ssid: !secret wifi_ssid
captive_portal:
web_server:
port: 80
- platform: adc
pin: GPIO33
update_interval: 500ms
attenuation: 11db
accuracy_decimals: 2
filters:
- lambda: |-
return (x);
on_value:
then:
- homeassistant.service:
service: light.turn_on
entity_id: light.garage_light
#brightness: !lambda { return (x - 225.0) * 2 }
Thank
