blackiemei
(blackiemei)
October 10, 2019, 5:05am
1
Thanks to Burningstone . I’ve got the right configuration.Here is the control Multiple devices throw wake on lan configuration.yaml.
switch:
- platform: wake_on_lan
mac_address: "4C-CC-6A-7F-5B-04"
host: your ipaddress
mac_address: "4C-ED-FB-BB-DF-CB"
Did you add
wake_on_lan:
to your configuration.yaml?
Also name1, name2, mac_address1,mac_address2 etc. will not work. The configuration looks for name and mac_address without the number afterwards. You need to separate it into 2 switches. Did you configure the hosts to be able to be woken up by LAN, does wake on LAN work when you send a magic packet from another device?
blackiemei
(blackiemei)
October 10, 2019, 5:56am
4
# PopeyesLaptop turn on
switch:
host: 192.168.1.155
# Popeyesdesktop turn on
switch:
host: 192.168.1.91
Here is format code. My Homeassistant only recognized the laptop switch.
blackiemei
(blackiemei)
October 10, 2019, 5:59am
5
Yes.I added wake on lan to my configuration.yaml
And the laptop switch can control my laptop. The desktop doesn’t show on the homeassistant. The wake on lan platform only control one device. I want to control two devices.
tom_l
October 10, 2019, 6:01am
6
Screenshots don’t make it easy for people to answer you. Please read point 11 here: How to help us help you - or How to ask a good question
blackiemei
(blackiemei)
October 10, 2019, 6:04am
7
Sorry for that. I’ve post the code.
Try like this:
switch:
host: 192.168.1.155
host: 192.168.1.91
blackiemei
(blackiemei)
October 10, 2019, 6:28am
9
Thanks a lot! It’s working!!!
Seems like latest wake on lan needs “mac” not “mac_address” and the docs example doesn’t reflect this. But I’m a major amateur so I don’t want to edit the documentation page and screw something up.
error420
(Randré Wright)
February 21, 2021, 8:35pm
11
Agreed. Tested with mac: instead of mac_address: and it works as a switch.
I have the problem that the Family NUC is not waking up properly. The Workstation is functional.
When I WOL them thorugh my MAC both work. But with the script in config … only Workstations works?
# WOL - Workstation
mac: "04-92-***"
host: 192.*** *(ip of host system)*
broadcast_address: 192.*** *(ip of host system)*
broadcast_port: 9
turn_off:
service: script.workstation_shutdown
# WOL - Family NUC
mac: "88-AE-***"
broadcast_port: 9
turn_off:
service: script.nuc_shutdown
