jascdk
(Jascdk)
October 27, 2019, 5:58am
1
Hi fellas
I have a MQTT controlled floor heating system in the whole house. Each room is controlled by a sensor, that reports back to the unit, which reports to the MQTT broker.
The code for example one room looks like this:
climate:
- platform: mqtt
modes:
- 'off'
- 'heat'
current_temperature_topic: 'heat/floorB4E62D292F41/0/current'
temperature_command_topic: 'heat/floorB4E62D292F41/0/target_set'
temperature_state_topic: 'heat/floorB4E62D292F41/0/target'
availability_topic: 'heat/floorB4E62D292F41/online'
payload_available: 'True'
payload_not_available: 'False'
mode_state_topic: 'heat/floorB4E62D292F41/0/output'
mode_state_template: >-
{{ 'heat' if value == 'on' else 'off' }}
qos: 0
I have multiple of these entities, but is there a way to control all with just one thermostat card or how do I do it best?
Best regards
Jacob
lolouk44
(lolouk44)
October 28, 2019, 2:45pm
2
create a simple automation that triggers on changes to your āmasterā thermostat and reflects changes to your āslaveā thermostats
Define which will be master for your lovelace card
Would you mind showing an example.i tried this way and it will switch between off and selected mode all the time .
lolouk44
(lolouk44)
June 4, 2020, 8:38am
4
you first need to create a template sensor that gets the target temperature:
sensors:
thermostat_target_temp:
friendly_name: "Thermostat Target Temp"
entity_id: climate.master_thermostat_name
unit_of_measurement: 'Ā°C'
value_template: "{{ state_attr('climate.master_thermostat_name', 'temperature') }}"
then create an automation that changes the slave thermostat target temp:
- alias: Thermostat - Set Slave Target Temperature
- platform: state
entity_id: sensor.thermostat_target_temp
- service: climate.set_temperature
data_template:
entity_id: climate.slave_thermostat_name
temperature: "{{states('sensor.thermostat_target_temp')}}"
I solved my loop problem with a delay of 1 second this is my whole config if someone might be interested
# AC Bedroom Sensors for Thermostat
# AC Bedroom
sensors:
ac_bedroom_hvac_mode:
entity_id: climate.air_conditioner_bedroom
value_template: "{{ states.climate.air_conditioner_bedroom.state }}"
friendly_name: AC Bedroom HVAC Mode
ac_bedroom_temperature:
value_template: "{{ state_attr('climate.air_conditioner_bedroom', 'temperature') }}"
friendly_name: AC Bedroom Temperature
ac_bedroom_fan_mode:
value_template: "{{ state_attr('climate.air_conditioner_bedroom', 'fan_mode') }}"
# Thermostat
thermostat_bedroom_hvac_mode:
entity_id: climate.bedroom_ac_control
value_template: "{{ states.climate.bedroom_ac_control.state }}"
friendly_name: Thermostat Bedroom HVAC Mode
thermostat_bedroom_temperature:
value_template: "{{ state_attr('climate.bedroom_ac_control', 'temperature') }}"
friendly_name: Thermostat Bedroom Temperature
thermostat_bedroom_fan_mode:
value_template: "{{ state_attr('climate.bedroom_ac_control', 'fan_mode') }}"
###################################### END ###########################################################
And the automations:
# # Bedroom Thermostat
## HVAC Mode
- alias: Thermostat - Set Slave HVAC Mode
- platform: state
entity_id: sensor.thermostat_bedroom_hvac_mode
- delay:
seconds: 1
- service: climate.set_hvac_mode
data_template:
hvac_mode: "{{ trigger.to_state.state }}"
- alias: Thermostat - Set Master HVAC Mode
- platform: state
entity_id: sensor.ac_bedroom_hvac_mode
- delay:
seconds: 1
data_template:
## Temperature
- alias: Thermostat - Set Slave Temperatue
- platform: state
entity_id: sensor.thermostat_bedroom_temperature
- delay:
seconds: 1
data_template:
temperature: "{{ trigger.to_state.state }}"
- platform: state
entity_id: sensor.ac_bedroom_temperature
- delay:
seconds: 1
data_template:
## Fan Mode
- alias: Thermostat - Set Slave Fan Mode
- platform: state
entity_id: sensor.thermostat_bedroom_fan_mode
- delay:
seconds: 1
- service: climate.set_fan_mode
data_template:
fan_mode: "{{ trigger.to_state.state }}"
- platform: state
entity_id: sensor.ac_bedroom_fan_mode
- delay:
seconds: 1
data_template:
daenny
(Daniel Claes)
June 12, 2020, 1:03pm
6
I have made an initial (not tested) implementation here to my climate_group
component:
daenny:master
ā daenny:feature/master-sync
opened 12:55PM - 12 Jun 20 UTC
you have to add:
master_device: entity
to your config of the climate group. Maybe that is useful for some people.
