Does anybody has an ID how to send hex commands via TCP/IP to an ETH484 to switch a relay and also get some feedback from it? What platform or code do I have to use?
The command set can be found on the following link: http://www.robot-electronics.co.uk/htm/eth484tech.htm
(somewhere in the middle). Does work perfectly with Packet Sender…
The goal is to control some lights in my house with push buttons.
Thanks in advance,
Niels
