Hi there !
I have a simple Q: why is switching OFF always prio 1 against capture it by automation ?
Or closer: I wanted to create a children cycle protection (KinderSpielSchutz) in automation - for that its necessary to control the switch OFF mechanisms !
The algo is simple:
if switching on by switch - setup a timer e.g .5 minutes
while the timer is running - no switching off at all …
only if the timer comes into idle mode an upcoming switch off command can take place now and only now !!
not necessary to say, I don’t accept bouncing of the lights, e.g. it’ll be recognised its switched off, so quickly switch it on again !!
please help me…
Thanks.
