NOTE!
Since this how-to was posted originally in the summer 2022, new integration has been developed by @Markus98 in the beginning of 2026 and from HA-version 2026.6 onwards it will be official Home Assistant integration (also by @Markus98), this thread is now more like historical reference and technical background.
Integration is preferable to this original method, however, original method provides lot of technical insight into EH-800 internal workings. Original integration for EH-800 is available for download at GitHub - Markus98/ouman-eh-800-ha: Ouman EH-800 heating controller integration for Home Assistant · GitHub and official integration is available at core/homeassistant/components/ouman_eh_800 at dev · home-assistant/core · GitHub
@Belaial provides registers and other valuable information in GitHub Belaial/Ouman-EH800---Home-Assistant: Ouman EH-800 - Home Assistant integration
INTRODUCTION
This how-to is all about using Ouman EH-800 heating controller with Home Assistant. Ouman EH-800 is versatile and very popular heating controller in Finland for heating systems using water as transfer medium, both for the radiators and floor heating.
Prerequisites:
- Ouman EH-800 controller, connected to ethernet (EH-800B won't do, it has no Ethernet)
- IP address, user and password configured in EH-800
- basic knowledge on Home Assistant configuration files and tools
- your EH-800 is properly configured and working
My heating system uses low temp water, so it doesn't even need thermostats, so thermostats are not included in config example, yet they work exactly same way by reading and writing registers usin curl and cut. Part of the information, mostly register functions, are based on the information on Finnish maalampofoorumi.fi (geothermal energy). I'm using split configuration files. Output for curl-commands are saved in three text files in HA \config directory and state is read using cut-command, which read proper bit location(s). You can save results in other directory than \config, but then, be prepared to mess with user rights (is it really worth it?).
First, make sure you can access your EH-800 management web-page. If you can't, controlling it using HA doesn't work! EH-800 uses simple login, which needs to be refreshed regularly, I use 5 min refresh interval using automation. This example has three functions, yet many more can be implemented using same principle:
- temperature dropping using switch on HA (home/away-function, can be useful in summer)
- show temp request for circulation water
- show actual temp for circulation water
My EH-800 has IP address 192.168.1.211 and web-server is configured to port 8090.
CODE
In config.yaml required shell commands are specified. Update-commands change setting (away/home), while request-commands read. Login results are piped to null, since there is no reason to save them, after you see them working. You can test all commands in terminal.
config.yaml
shell_command:
ouman_logon: 'curl "http://192.168.1.211:8090/login?uid=username;pwd=password;" > /dev/null'
ouman_ltp_kotona: 'curl "http://192.168.1.211:8090/update?S_135_85=0;" --output /config/oumanltp.txt'
ouman_ltp_poissa: 'curl "http://192.168.1.211:8090/update?S_135_85=1;" --output /config/oumanltp.txt'
ouman_ltp_kysely: 'curl "http://192.168.1.211:8090/request?S_230_85;" --output /config/oumanltp.txt'
ouman_menovesi_kierto: 'curl "http://192.168.1.211:8090/request?S_259_85" --output /config/oumankierto.txt'
ouman_menovesi_pyynto: 'curl "http://192.168.1.211:8090/request?S_275_85" --output /config/oumanpyynto.txt'
switch:
- platform: command_line
switches:
eh800ltp:
friendly_name: EH_lampotila_pudotus
command_on: >
command_off: >
command_state: >
cut -b 17 /config/oumanltp.txt
value_template: '{{ value == "1" }}'
sensor.yaml
command: cut -b 18-21 /config/oumankierto.txt
unit_of_measurement: "°C"
command: cut -b 18-21 /config/oumanpyynto.txt
binary_sensors.yaml
command: cut -b 17 /config/oumanltp.txt
payload_on: 1
payload_off: 0
automations.yaml
- id: '1657895187329'
alias: Ouman-toiminnot
description: Automaattinen kirjautuminen Ouman EH800, kiertoveden lämpötila ja lämpötilapyyntö,
5min välein
- platform: time_pattern
minutes: /5
condition: []
- service: shell_command.ouman_logon
data: {}
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- service: shell_command.ouman_menovesi_pyynto
data: {}
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- service: shell_command.ouman_menovesi_kierto
data: {}
mode: single
Automation is probably easiest to generate using HA Automation tool. Automation runs every 5 min, it calls first login, waits 5 seconds and calls other states to update, 5s wait between every call.
If you are having problem with files, create empty files in config editor and execute sudo -R 777 filename in terminal for every file beginning with ouman and ending to .txt
Other known registers (from maalampofoorumi.fi and this community) and settings:
- S_259_85: L1 Menoveden lämpötila / Water temp to heater
- S_227_85: Ulkolämpötila / Outdoor temp
- S_261_85: L1 Huonelämpötila / Room temp
- S_272_85: L1 Venttiilin asento / Valve position
- S_102_85: Huonelämpötilan hienosäätö / Room temp offset (thanks Vivillik!)
L1 is heating circuit number 1 and always present, you may have circuit L2 too. In other language versions than Finnish these circuits are V1 and V2 (thanks Belaial!)
Edit: added some register / setting information discovered afterwards.
And for me, I tried this in order to proof, that EH-800 and HA can be used together.
I have floor heating and as such, system doesn’t really need room thermostats. If you have traditional water-radiators, more fine-grained adujstment would be useful. Ouman itself offers all the needed commands and responses. There is no technological barrier for example, adjusting heating curve for EH800 from Home Assistant.
