Hi there,
today I finally managed to install my Z-Wave empowered roller shutter with the fuse only blowing two times Now that I hooked up the device to my HA system, I like to control the device within some Node-Red flows. However, I have a little exceptional setup which is as follows:
- Home Assistant Blue (HAB): This is where my Node-Red Add-On is being installed
- Rasp Pi 4: This is where the roller shutter is connected to (using the “Z-Wave JS to MQTT” - Gateway)
I managed to install the “node-red-contrib-zwave-js” palette, but when trying to configure the “Z-Wave JS Controller” node, I´m prompted to select a serial port. But as the Z-Wave controller Stick is connected to the Pi4, and not the HAB, there is no proper choice for me to select. Is there any other way to control my devices in Node-Red?
