How can I copy a sensor with a numerical value into a new sensor, but if the numerical value is greater than 0, the new sensor should be ON if the numerical value = 0, the sensor should be OFF.
Thank you
Thank you
Looks like simple binary_sensor:
binary_sensor:
publish_initial_state: True
lambda: return (id(XXX).state > 0);
Can write in lambda
whatever You want, like check if state exists ever (id(XXX).has_state()
Thank you, works perfect.
i searched about an hour but that was easy
