I have been using Tasmota to send and receive IR signals successfully. I would like to use my Tasmota-captured IR codes with an ESPHome IR Sender.
However, I’m having trouble with the terminology. The code in question is this:
{“Protocol”:“NEC”,“Bits”:32,“Data”:“0xFF38C7”,“DataLSB”:“0xFF1CE3”,“Repeat”:0}
Looking at the ESPHome specification, for NEC it wants:
- address (Required, int): The address to send, see dumper output for more details.
- command (Required, int): The NEC command to send.
I presume it is a matter of masking off the right bit patterns. However, I cannot find a conversion guide from Tasmota format to ESPHome format.
Can anyone point me at the appropriate resource please?
Thanks!
B.
