How to Convert Jalali date to Gregorian
hi
I want to convert Jalali date to Gregorian and display it on lcd
But I don’t know how to do it
ESPHome
esphome:
  on_boot:
    then:
      - ds1307.read_time:
      - script.execute: update_shamsi_date
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
   logs:
    component: none
# Enable Home Assistant API
api:
  reboot_timeout: 0s
ota:
 - platform: esphome
   password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
  reboot_timeout: 0s
time:
  - platform: sntp #homeassistant
    on_time_sync:
      then:
        # ... and update the RTC when the synchronization was successful
        - ds1307.write_time:
    on_time:
      - seconds: 0
        minutes: 0
        hours: 0
        then:
      - seconds: /1
        then:
           - lambda: |-
               id(secbit) = ! id(secbit);
  - platform: ds1307
    i2c_id: i2c_clock
    update_interval: never
globals:
  - id: secbit
    type: bool
    initial_value: 'true'
# Example configuration entry with 2 sensors and filter
script:
  - id: update_shamsi_date
    then:
      - lambda: |-
          time_t curr_time = id(my_time).now().timestamp;
          struct tm *timeinfo = localtime(&curr_time);
          int gy = timeinfo->tm_year + 1900;
          int gm = timeinfo->tm_mon + 1;
          int gd = timeinfo->tm_mday;
          auto gregorian_to_jalali = [](int gy, int gm, int gd, int &jy, int &jm, int &jd) {
            int g_d_m[] = {0, 31, 59, 90, 120, 151, 181, 212, 243, 273, 304, 334};
            jy = (gy <= 1600) ? 0 : 979;
            gy -= (gy <= 1600) ? 621 : 1600;
            int gy2 = (gm > 2) ? (gy + 1) : gy;
            int days = (365 * gy) + ((gy2 + 3) / 4) - ((gy2 + 99) / 100) + ((gy2 + 399) / 400) - 80 + gd + g_d_m[gm - 1];
            jy += 33 * (days / 12053);
            days %= 12053;
            jy += 4 * (days / 1461);
            days %= 1461;
            jy += (days - 1) / 365;
            if (days > 365) days = (days - 1) % 365;
            jm = (days < 186) ? 1 + (days / 31) : 7 + ((days - 186) / 30);
            jd = 1 + ((days < 186) ? (days % 31) : ((days - 186) % 30));
          int j_year, j_month, j_day;
          gregorian_to_jalali(gy, gm, gd, j_year, j_month, j_day);
          char shamsi_date[22];
          snprintf(shamsi_date, sizeof(shamsi_date), "%04d/%02d/%02d", j_year, j_month, j_day);
          id(shamsi_date_text).publish_state(shamsi_date);
          id(shamsi_year).publish_state(j_year);
          id(shamsi_month).publish_state(j_month);
          id(shamsi_day).publish_state(j_day);
          ESP_LOGD("custom", "Gregorian Date: %04d-%02d-%02d", gy, gm, gd);
          ESP_LOGD("custom", "Shamsi Date: %s", shamsi_date);
text_sensor:
    icon: "mdi:calendar"
i2c:
 - id: i2c_disp
   sda: 18
   scl: 5
  # scan: false
 - id: i2c_clock
   sda: 22
   scl: 23
#  #  scan9 false
display:
  - platform: ssd1306_i2c
    i2c_id: i2c_disp
    update_interval: 0.5s
    contrast: 1
    model: "SH1106 128x64"
    rotation: 0
    auto_clear_enabled: true
    #scan_interval: 1000
    address: 0x3C
    lambda: |-
      it.printf(0, 6, id(my_font1), "%s", id(shamsi_date_text).state.c_str());
      if (id(secbit)) {
         it.strftime(it.get_width()/2, 26, id(my_font), TextAlign::TOP_CENTER, "%H   %M", id(my_time).now());
       else {
         it.strftime(it.get_width()/2, 26, id(my_font), TextAlign::TOP_CENTER, "%H : %M", id(my_time).now());
font:
  - file: "_fonts/BTitr-Bold.ttf"   #"_fonts/TAHOMAB0.ttf"
[quote=“sadeghelect, post:2, topic:717890”]
esphome:
  on_boot:
    then:
      - ds1307.read_time:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
   logs:
    component: none
api:
  reboot_timeout: 0s
ota:
 - platform: esphome
wifi:
  reboot_timeout: 0s
time:
    on_time_sync:
      then:
    on_time:
      - seconds: 0
        minutes: 0
        hours: 0
        then:
      - seconds: /1
        then:
           - lambda: |-
  - platform: ds1307
    i2c_id: i2c_clock
globals:
  - id: secbit
    type: bool
script:
    then:
      - lambda: |-
            days %= 12053;
            days %= 1461;
text_sensor:
i2c:
 - id: i2c_disp
   sda: 18
   scl: 5
  # scan: false
 - id: i2c_clock
   sda: 22
   scl: 23
#  #  scan9 false
display:
    i2c_id: i2c_disp
    contrast: 1
    rotation: 0
    address: 0x3C
    lambda: |-
      if (id(secbit)) {
       else {
font:
```کارت درسته
hi :wave:
Blockquote
سلام خدمت همه پارسی زبانان تقویم جلالی با فونت فارس خدمت شما عزیزان
