How to convert UART-string with spaces to values
Hi, everybody,
I’m new to this community.
I’d like to get a string from the UART and divide it up in several values.
basically it works. Communication is fine, the raw string is shown up correctly.
Unfortunately the string contains spaces and comma separated float values. Conversion stops at first space. To handle this, my idea was to do something with
std::replace,
but compiler says no.
How can I do this in ESPhome?
Format of the string is different like:
11:22:33 12,3 234,5 1:3 2:4\r\n
11:22:34 1,5 -24,5 1:254 2:12\r\n
uart:
  baud_rate: 9600
  tx_pin: 1
  rx_pin: 3
  debug:
    direction: RX
    dummy_receiver: true
    after:
      delimiter: "\r\n"
    sequence:
      - lambda: |-
          UARTDebug::log_string(direction, bytes);  // log the data
          int iTime,iHour,iMinute,iSecond,idata1,idata2=0;
          float fTemp1,fTemp2,=0;
          // convert uart text to string
          std::string str(bytes.begin(), bytes.end());
          // get raw string
          id(rawString).publish_state(str.c_str());          // data comes in correct
          //std::cout<<strString<<std::endl;                 // this do not work
          //std::replace (str.begin(), str.end(), ",", ";"); // this too
          id(convString).publish_state(str.c_str());
          // teststring to values
          if (sscanf(str.c_str(), "%d:%d:%d %f %f 1:%d 2:%d", &iHour, &iMinute, &iSecond, &fTemp1, &fTemp2, &idata1, &idata2) == 7 ) { // seems to stop at a space?!
            id(hour).publish_state(iHour);
            id(minute).publish_state(iMinute);
            id(second).publish_state(iSecond);
            id(temp1).publish_state(fTemp1);
            id(temp2).publish_state(fTemp2);
text_sensor:
