Tsar
(Christian)
1
It must be simple, but I don’t know…
How to copy the value from the helper ‘input_number.number_solar_panel_1’ to the helper ‘input_number.number_solar_panel_initialisation_1’ ?
This seems not to work…
- service: input_number.set_value
value: {{ states('input_number.number_solar_panel_1') | float(0) }}
entity_id: input_number.number_solar_panel_initialisation_1
tom_l
2
Quote your single line templates.
value: "{{ states('input_number.number_solar_panel_1') }}"
Hi all,
it seems it is not working with me.
The input variables changes and it is defined.
tom_l
5
Using my example:
not
data: "{{ states('input_number.number_solar_panel_1') }}"
(you are missing the value:
bit).
And you don’t need the |float
filter in your template this time. The set_value action can use a string representation of a number.
