How to copy values from one entity to another
Hi, I have 2 thermostatic valve in one room (Eurotronics Sprint, zwave) and I want to syncrozies them, meaning, if I change manually valve1 that the settemp is sent to valve2. It is possible to set a value via script but not the value from an anther on?
alias: Testscript
sequence:
  - service: climate.set_temperature
    entity_id: climate.thermostat_valve_2
    data_template:
      temperature: 20
mode: single
works perfectly, but here
alias: Testscript
sequence:
    data_template:
      temperature: {{ state_attr("climate.thermostatic_valve","temperature") }}
mode: single
the value of the attribute is not recognized / empty. The template works fine in dev.-tool / template. Any hint?
Maybe this is a string and then you need to the int filter:
{{ state_attr(ā€œclimate.thermostatic_valveā€,ā€œtemperatureā€) | int }}
You can try it in the developer tools, there is a section to develop templates
Wrap it with quotes:
temperature: "{{ state_attr('climate.thermostatic_valve', 'temperature') }}"
Edit: Corrected wrong quotes
Thank you for tip, but unfortunately no change. Both things I tested in develop templeates. It seems to me, that this expression is ignored. If I would test it in script editor, the expression will be changed to {} :frowning:
What is the result of the above in Dev Tools? If it is ā€žnoneā€œ, it is not an attribute. Check it under Dev Tools → States
The result is the desired set temperture:
So the value looks correct now but it’s still not working to set it to valve_2 ?
No, unfortunately not: ā€œError rendering data template: Result is not a Dictionaryā€
This works for me: (and note the different quotes)
  entity_id: climate.ir_heizung_wz
  temperature: "{{ state_attr('climate.ir_heizung_sz', 'temperature') |float}}"
Thank you, that’s it! I did in this way and it works now:
