Home Assistant OS 5.12 - core-2021.3.3
I just noticed that my weather info was incorrect. At first I assumed the problem was at source ( Meteorologisk institutt) - so I changed that to OpenWeatherMap. Still getting wrong temps. I then thought i must have long/lat wrong but the map looked right. So i looked up how to explicity define long/lat in configuration and restarted. Same issue. After some fiddling around I discovered that .storage/core.config-entries has an entry for OpenWeatherMap and the listed long/lat is indeed incorrect. No idea how that happened? How to do I get that entry corrected to go to the long/lat in my config? I assume I shouldn’t just edit the .storage file.
Still learning and would appreciate any help.
Cheers
Bill
