I use the fibaro fgr 222 for my roller shutters. Unfortunately there is a small shift in the position value. E.g when the shutter is open it states 99% and not 100%. This shift gets worse over the time and the roller shutter has to be recalibrated.
To avoid this I want to correct the position value 15 seconds after a shutter has been moved:
if position > 98% set position to 100%
if position < 2% set position to 0%
How could this automation be done for a group of roller shutters?
Thanks!
