How to correctly install Python Package requirement in Custom Component?
Hi there, im currently trying my luck in setting up a custom component with a already released python package as requirement.
However, when trying to import from it in my __init__py i always get the error that it is not found. Therefore my guess is, that the requirement is actually not installed.
My Manifest looks like this:
  "domain": "test",
  "name": "Freenet Funk",
  "requirements": [
     "funkapi==0.1.5"
  "dependencies": [
and my __init__py like this:
DOMAIN = 'test'
def setup(hass, config):
    from funkapi import FunkAPI
    api = FunkAPI("USERNAME", "PASSWORD")
    currentTariff = api.getCurrentTariff()
    hass.states.set('test.world', 'TEST1234')
    hass.states.set('test.world2', currentTariff)
    # Return boolean to indicate that initialization was successful.
    return True
The error is the following:
2019-07-21 23:40:01 ERROR (MainThread) [homeassistant.setup] Error during setup of component test
  File "/usr/src/homeassistant/homeassistant/setup.py", line 156, in _async_setup_component
    component.setup, hass, processed_config)  # type: ignore
  File "/config/custom_components/test/__init__.py", line 5, in setup
ModuleNotFoundError: No module named 'funkapi'
What did i do wrong?
How do i make hassio install the the pip3 funkapi?
anybody looking for the same… you need to import the python library first.
DOMAIN = 'test'
    import funkapi
