Earlier today I wanted to post here I’m having the same troubles. Though after reconnecting several times and rebooting HomeAssistant, I just saw the climate.danfoss_popp_radiator_thermostat_heating_1 appeared in the list of devices and I can now control the device
I’m sorry for not being able to give a clear explanation. Maybe it will work for you too when rebooting Home Assistant or/and reconneting the Popp radiator thermostat?
are your TRV’s working well? I have 7 of them and have problem with setting heating temperature. It happens quite often, that when I set a temperature on the climate object, the value never gets to the TRV.
I’m running HA on RPI4 with ZWave.me controller and OpenZWave.
I had no problem including the TRV’s, i get regularly temperature updates from them, but this one thing doesn’t work reliable. I moved from Zipabox and i had no problems with TRV.
Can anybody help? Should I check some config parameters, increase some ack parameter? Or is the problem in network? (i have 1 range extender and 4 fibaro FGR-222, so mesh should be ok)
I use schedulers to turn down the temperature in the evening and up in the morning. And it is not pleasant, when the temperature in the morning stays down.
I just got myself a couple of the Popp thermostats, added them in my tellstick znet lite v2. They show up in home assistant with a binary and temperature sensor. But no climate control.
I have followed the instructions provided, keeping the thermostats close to the base station during pairing, without any success.
I’m at a loss, anyone able to give me a nudge in the right direction?
I think we might be looking at a similiar issue to this:
This right here creates a pretty high entry barrier for some people. Which is exactly what I would like help stomping out. If there is anything you want me to test with the hardware just give me a shout.
