I ended up (with considerable assistance from an AI entity whose name I’m not supposed to mention here but starts with “C” and with whom I get along fabulously!) with this python_script:
# count_words.py
message = data.get("message", "")
result_string = ""
# Function to convert numbers to words
def number_to_words(n):
ones = ["", "one", "two", "three", "four", "five", "six", "seven", "eight", "nine"]
teens = ["", "eleven", "twelve", "thirteen", "fourteen", "fifteen", "sixteen", "seventeen", "eighteen", "nineteen"]
tens = ["", "ten", "twenty", "thirty", "forty", "fifty", "sixty", "seventy", "eighty", "ninety"]
if n == 0:
return "zero"
if n < 10:
return ones[int(n)]
elif 10 < n < 20:
return teens[int(n) - 10]
elif n < 100:
return tens[int(n // 10)] + (" " + ones[int(n % 10)] if n % 10 != 0 else "")
elif n < 1000:
return ones[int(n // 100)] + " hundred" + (" and " + number_to_words(n % 100) if n % 100 != 0 else "")
else:
return str(n) # Handle numbers beyond the scope
def decimal_to_words(num):
whole, fraction = str(num).split(".")
whole_words = number_to_words(int(whole))
fraction_words = "point " + " ".join(number_to_words(int(digit)) for digit in fraction)
return whole_words + " " + fraction_words
# Process the message
word_list = message.split()
for word in word_list:
if word.replace('.', '', 1).isnumeric(): # Handle decimal numbers
if "." in word:
num_as_words = decimal_to_words(float(word))
else:
num_as_words = number_to_words(int(word))
result_string += num_as_words + " "
else:
result_string += word + " "
# Remove trailing space
result_string = result_string.strip()
# Count words in the new string
word_count = len(result_string.split())
# Output the word count and debug information
output = {
"word_count": word_count,
"debug_message": f"Processed message: '{message}' to '{result_string}' with word count: {word_count}"
and my main HA script that uses it:
alias: "Alexa: Notify Alexa Media Last Called"
description: Send notification to sensor.last_alexa
fields:
message:
description: The message content
example: I am notifying you
sequence:
- action: python_script.count_words
message: "{{ message }}"
response_variable: word_count
- action: system_log.write
message: "{{ word_count.debug_message }}"
level: info
- action: python_script.notify_alexa_media_last_called
- delay:
seconds: >-
{{ word_count.word_count * states('input_number.alexa_word_duration') |
float(0.5) }}
alias: Delay for word count * input_number.alexa_word_duration
mode: queued
icon: mdi:account-voice
max: 10
and the execution trace shows as:
Executed: January 9, 2025 at 5:32:46 AM
Result:
params:
domain: system_log
service: write
service_data:
message: >-
Processed message: 'Your E V range is 279.7 kilometres.' to 'Your E V
range is two hundred and seventy nine point seven kilometres.' with word
count: 13
level: info
target: {}
running_script: false
BTW, “Her” last reponse was…
You’re very welcome!
It’s great to see everything working smoothly now, including the correct word count and logs displaying as expected. If you need further help in the future—whether with Home Assistant or anything else—don’t hesitate to reach out. Happy automating, and have a fantastic day!
