How to create a list of multiple rooms to clean within an automation
Currently i am using node-red to start my roborock vacuum to clean selected rooms.
Therefore i added a function node that evaluates which rooms are selected.
var myarray=[]
for (var i = 0; i < msg.payload.length; i++) {
    if (msg.payload[i].entity_id == "input_boolean.raumauswahl_flur_technik") {
        myarray.push(21);
    else if (msg.payload[i].entity_id == "input_boolean.raumauswahl_kuche") {
        myarray.push(20);
    else if (msg.payload[i].entity_id == "input_boolean.raumauswahl_wohnzimmer") {
        myarray.push(23);
    else if (msg.payload[i].entity_id == "input_boolean.raumauswahl_waschkuche") {
        myarray.push(17);
    else if (msg.payload[i].entity_id == "input_boolean.raumauswahl_alte_kuche") {
        myarray.push(22);
    else if (msg.payload[i].entity_id == "input_boolean.raumauswahl_gaste_wc") {
        myarray.push(16);
    else if (msg.payload[i].entity_id == "input_boolean.raumauswahl_flur_eingang") {
        myarray.push(19);
    else if (msg.payload[i].entity_id == "input_boolean.raumauswahl_esstisch") {
        myarray.push(18);
msg.payload = myarray
return msg;
Is there a similar way to achieve this in a home assistant automation?
In the end i need a automation that creates the following service call:
service: vacuum.send_command
  command: app_segment_clean
  params:
    - segments:
        - 22
        - 23
      repeat: 2
  entity_id: vacuum.s7_roborock
What i need to create dynamically is the list of the segments.
In your Node-Red flow, msg.payload contains a list of Input Booleans. The for-loop iterates through the list and checks if it contains the entity_id any of six specific Input Booleans. For each matching Input Boolean, it appends its associated integer value to a list.
What in Home Assistant contains this list of Input Booleans?
In other words, how do you plan to tell the automation which rooms you want to have vacuumed?
That is exactly my question, how can i achieve this.
I have those input_booleans and need the list → the values for the segment parameter.
Let me re-phrase my question.
How are you currently telling your Node-Red flow which rooms you want vacuumed?
You appear to have a Function node that receives msg.payload containing a list of Input Booleans. What is/are the previous node(s) in your flow that is producing the list of Input Booleans and passing it to your Function node via msg.payload?
Ah got it. Its an „get entities„ node and „in group“ selection within that node
So a group entity contains the list of input_boolean entities?
What is the group entity’s entity_id?
Its
group.raumauswahl_erdgeschoss_alle_raume
  - service: vacuum.send_command
      params:
        - segments: >
            {% set rooms = {
              "input_boolean.raumauswahl_flur_technik": 21,
              "input_boolean.raumauswahl_kuche": 20,
              "input_boolean.raumauswahl_wohnzimmer": 23,
              "input_boolean.raumauswahl_waschkuche": 17,
              "input_boolean.raumauswahl_alte_kuche": 22,
              "input_boolean.raumauswahl_gaste_wc": 16,
              "input_boolean.raumauswahl_flur_eingang": 19 } %}
            {% set ns = namespace(room_numbers=[]) %}
            {% for room in state_attr('group.raumauswahl_erdgeschoss_alle_raume', 'entity_id') %}
            {% set ns.room_numbers = ns.room_numbers + [rooms.get(room)] %}
            {% endfor %}
            {{ ns.room_numbers }}
      repeat: 2
Wow thank you!
The example from 123 is efficient!
I do the same thing, but with extra steps. I put all my “segments” code into a template sensor, then point to that for the params in the service call.
I add my room numbers as attributes on the input booleans using customize.yaml:
CONFIG > customize.yaml
input_boolean.raumauswahl_flur_technik:
  room_id: "21"
input_boolean.raumauswahl_kuche:
  room_id: "20"
input_boolean.raumauswahl_wohnzimmer:
  room_id: "23"
input_boolean.raumauswahl_waschkuche:
  room_id: "17"
input_boolean.raumauswahl_alte_kuche:
  room_id: "22"
input_boolean.raumauswahl_gaste_wc:
  room_id: "16"
input_boolean.raumauswahl_flur_eingang:
  room_id: "19"
Then make sure you tell home assistant about the customize.yaml file. Place the following in
CONFIG > configuration.yaml:
homeassistant:
  customize: !include customize.yaml
By doing this type of attribute customization, you might then create a template sensor helper with the following: (I named mine “sensor.active_vacuum_zones”)
{% set ns =namespace(COMMAND = "") -%}
{%- set ROOM_FLAGS = expand("group.raumauswahl_erdgeschoss_alle_raume") | selectattr("state", "eq", "on") | list-%}
{%- for flag in ROOM_FLAGS -%}
  {%- set ROOM_NUMBER = flag.attributes.room_id -%}
  {% if loop.last %}
    {%- set ROOM_NUMBER_STR = (ROOM_NUMBER|string) -%}
  {% else %}
    {%- set ROOM_NUMBER_STR = (ROOM_NUMBER|string +",") -%}
  {% endif %}
  {%- set ns.COMMAND = ns.COMMAND + ROOM_NUMBER_STR -%}
{%- endfor -%}
[{{ ns.COMMAND }}]
Now in your script code you call the list from the helper sensor:
  params:
    - segments: "{{ states('sensor.active_vacuum_zones') }}"
      repeat: 2
In my example, I used a dictionary to store the relationship between an Input Boolean and its associated room id.
In super60’s example, Manual Customization is used to store each Input Boolean’s room id in a custom attribute (named room_id).
If you store the room id in a custom attribute, it reduces the template to this:
      params:
        - segments: >
            {{ expand(state_attr('group.raumauswahl_erdgeschoss_alle_raume', 'entity_id') )
              | map(attribute='attributes.room_id')
              | map('int', 16) | list }}
      repeat: 2
I love this script but I would like to have it only vacuum the rooms I select–the rooms were the input_boolean for that room is on. The group contains all the rooms and correctly pulls the corresponding seqment numbers, but for my use case, I want to only vacuum the segments where the corresponding input_boolean segment(s) for the rooms have been turned on.
EDIT:
I figured out what I needed: from @123’s first example just add an if around making the room list:
        {% if states(room) == 'on' %}
        {% endif %}
I am trying to use this, but I am struggling creating a helper group (group.raumauswahl_erdgeschoss_alle_raume) containing all of my input_boolean helpers. The GUI doesn’t let me create a group containing those helpers, at least the entities can’t be found. Maybe I have to create the group via YAML? :slight_smile:
Or is there a better way to get @123 script working, without having to create a group that contains the boolean helpers?
Also, if all of my room helpers are set to OFF, I would like to clean all of the rooms. What’s a good way to achieve that? Add all room ids to “segments”?
Yes.
group entities cannot be created via the UI.
You could add a label to each Input Boolean and then, in the automation, select all Input Booleans having the same label.
Thanks, in the meantime I created a group via YAML. Seems to be working.
Now I only need to check somehow if all of the helpers are “off” and if so, then all rooms are supposed to be cleaned.
Did you find a good solution for this?
I use the group-boolean to turn all on but it would be a little bit cleaner without.
