How to create a new (Homewizard water) sensor to keep track of daily usage
The homewizard watermeter has two sensors that i can read (translated):
  • sensor.watermeter_actual_water_usage (which indicated the usage in Liter)
  • sensor.watermeter_total_water_usage (which indicates the usage in m3)
I’ve tried several things but i can’t get a new sensor that tracks the usage daily.
Besides other things, i tried the code below with the other (current) sensor as well but i can’t get it to work.
What am i doing wrong? I can see the sensor but the value stays zero
utility_meter:
  daily_water:
    source: sensor.watermeter_total_water_usage
    name: Water Usage Daily Utility Config
    cycle: daily
template:
  - sensor:
      - name: "Water Usage Daily"
        unique_id: water_usage_daily
        unit_of_measurement: "L"
        device_class: water
        state_class: total_increasing
        state: >-
          {{states('sensor.daily_water') | float(0)  * 0.001}}
If I am not mistaken; You can create a utility meter directly from the UI without having to make any YAML. After connecting the Water meter to Home Assistant you can create a daily-usage meter out of the box.
  1. Click here → Open your Home Assistant instance and show your helper entities.
  2. Then hit ‘Create helper’ → Utility meter
  3. Select ‘Total Liter’ from your water meter, and configure the rest (self explaining)
Hope this helps :+1:. if it does you can mark this as ‘solution’, that will help others.
Thanks for your quick reaction!
I tried that but the status was unknown:
After turning on the water to test,
It was working.
Thanks a lot for your help!
Because the total value is in m3,
I created a template so it could present the value in Liters.
  - sensor:
      - name: Daily_Water_Meter_in_Liter
        unit_of_measurement: L
        device_class: current
        state_class: measurement
        state: >
          {{ states('sensor.daily_water_meter') | float(default=0.0) | multiply(1000) | round(0) }}
The Liters are not being calculated correctly
Original :
Created one:
Where did i go wrong?
Because of the measurement in the helper i changed the template.
  - sensor:
        state: >
          {{ states('sensor.daily_water_meter') | float(default=0.0) | multiply(100) | round(2)}}
That seems to be working:
But with a larger amount this was not working so i had to bring it back to 1000.
It would be 16,6 and thats not good :slight_smile: So for a lower usage it is less accurate.
Is there a way to also print the decimal value if the volume is less then 10?
Just as Raptile I’m running into some issues.
I can’t get it to duplicate the values that the HomeWizard app is displaying
Could you paste your helper and dashboard card in this topic please?
i´m also struggling!
anybody got it working eventually?
This is working for me. I setup daily, weekly, monthly and quarterly helpers.
A couple things to check:
  • use the total consumption sensor (or make sure you specify during creation that it is a delta value)
  • know how often the sensor reports and watch the value in the devtools State tab to see if there is any change over time
  • if the helper isn’t working, try creating it in yaml. This also worked for me:
daily_water_use:
  source: sensor.watermeter_value
  cycle: daily
