How to create a new (larger)Home zone?
I like to create a larger Home zone.
How to arrange this?
At the moment I did make a larger circle around home, called “Thuis”
Will this work?
What happens if a device is in home and Thuis? What state will it be?
If you manually configure a Home zone it will override the default one:
Thanks about the answer.
I did read that allready and did test this also. I wonder if this realy is overruling the home zone, because it is creating an other zone called home_2
EDIT. I did found out that you can only do this in the configurayion.yaml.
Not adding a zone in zones at the settings chapter
What you mean?
did you find a solution? I’m also trying the same right now
yes.
You need to add a home zone in your configuration.yaml like
zone:
  - name: Home
    latitude: xx.685897958213125
    longitude: x.798847436904908
    radius: 400
    icon: mdi:home
where x is your coordinates
instead of the standard home zone?
Yes indeed
ok thank u. i use right now proximty area, its working like a charm (just for infomation)
I just tried this due to some proximity issues the last few months and works great, thank you. Curious, is there a max radius?
Thanks.
