I have this script that worked fine up to a few versions, but now it gives me an error in the log, how do I solve it?
Input Select:
numeri_canali:
icon: mdi:format-list-numbered
options:
- Seleziona canale
- Zero
- Uno
- Due
- Tre
- Quattro
- Cinque
- Sei
- Sette
- Otto
- Nove
initial: Seleziona canale
Script:
seleziona_numero:
alias: Seleziona Numero
sequence:
- service: input_select.set_options
data_template:
entity_id: input_select.numeri_canali
- service: script.turn_on
data_template:
entity_id: >-
{% if is_state("input_select.numeri_canali", "Zero") %} script.zero
{% elif is_state("input_select.numeri_canali", "Uno") %} script.uno
{% elif is_state("input_select.numeri_canali", "Due") %} script.due
{% elif is_state("input_select.numeri_canali", "Tre") %} script.tre
{% elif is_state("input_select.numeri_canali", "Quattro") %} script.quattro
{% elif is_state("input_select.numeri_canali", "Cinque") %} script.cinque
{% elif is_state("input_select.numeri_canali", "Sei") %} script.sei
{% elif is_state("input_select.numeri_canali", "Sette") %} script.sette
{% elif is_state("input_select.numeri_canali", "Otto") %} script.otto
{% elif is_state("input_select.numeri_canali", "Nove") %} script.nove
{% endif %}
Error:
2019-10-20 18:32:04 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall script.seleziona_numero (c:60bd95c243a84eb598c44fb96c3fbbde)>
File "/usr/src/homeassistant/homeassistant/core.py", line 1241, in _safe_execute
await self._execute_service(handler, service_call)
File "/usr/src/homeassistant/homeassistant/core.py", line 1258, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 142, in service_handler
await script.async_turn_on(variables=service.data, context=service.context)
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 214, in async_turn_on
raise err
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 209, in async_turn_on
await self.script.async_run(kwargs.get(ATTR_VARIABLES), context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 181, in async_run
await self._handle_action(action, variables, context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 265, in _handle_action
await self._actions[_determine_action(action)](action, variables, context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 348, in _async_call_service
context=context,
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 97, in async_call_from_config
domain, service_name, service_data, blocking=blocking, context=context
File "/usr/src/homeassistant/homeassistant/core.py", line 1211, in async_call
processed_data = handler.schema(service_data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 432, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: required key not provided @ data['options']
