How can I create a sensor to display the audio in format for a Sonos (Arc). I find myself checking that quite often and would like for a faster way to see it, or even make some automation around it.
I fixed it myself, if anyone interested:
#Sensor for Sonos Line-In format
- platform: scrape
resource: http://192.168.50.179:1400/status/zp
name: Sonos Arc Line-In
select: "HTAudioInCode"
value_template: >-
{% if value == '33554434' %}
Stereo
{% elif value == '84934714' %}
DD+
{% elif value == '84934713' %}
DD 5.1
{% elif value == '59' %}
Atmos
{% elif value == '21' %}
No Signal
{% elif value == '0' %}
No Signal
{% else %}
{{ (value | int)}}
{% endif %}
Thanks for this! Only when it did not work I discovered that for my system the “HTAudioInCode” codes were different (eg. Atmos = 63). Do these change with firmware updates?
I don’t know, but I stopped using that since now the integration provides by default a sensor on audio input format
