Looking for ideas on how to create a template sensor that provides the curve shown by the lower values of this sensor graph:
This is the output of a temperature sensor built into an ESP32 chip as provided by ESPHome. It tracks the CPU core temperature. The max value is always 53.3 degrees C (so far) and the low values varies with the outside temperature. I’m guessing when the CPU is working the high value is produced, and when idle the low value is produced.
I’d like to create a template sensor that tracks that lower curve (including if it goes above 53.3) so I can know if the device gets “too hot”. The device is in a weather tight box.
I’m guessing something like the statistics integration would be helpful here, but personal experience is limited in this area.
Any thoughts on how to produce a curve that varies with the idle temperature? I’m assuming I can’t just throw out the 53.3 C values as I don’t know if that will remain as the ceiling value once it gets hot here in South Texas.
