Hi, I’m working on a custom A/C controller which is able to set temperature, fan speed, mode, etc.
Now I want to integrate into HASS and searching online for a cool template, I found this one used by Sensibo controller:
I like it very much, and I want to create something like this.
Can anyone help me with this?
Or linking something like a guide/tutorial/etc.?
I was not sure so I created a demo climate component (https://github.com/avocadosalsa/hass-demo_climate) and found that the image you posted is basically the default control panel for a climate component. In mine the target temperature is a little bit different but I do not know why that is.
As far as a guide/tutorial I just looked at the source for the Sensibo component and the base climate component to figure out what I needed to implement. https://github.com/home-assistant/home-assistant/blob/dev/homeassistant/components/climate/init.py
Your topic caught my attention because I too am working on creating a new climate platform. I am still working on the backend so I am not to the point where I can get the data into HASS yet.
The demo you made is very cool!
I watched the code on github and I think it is a little bit advanced topic, I’m quite new to HASS.
As far as I understand, you created a new component, right? And you will add the new component in a similar way as reported in the link at page https://home-assistant.io/developers/creating_components/
Is correct?
I does not understand very well about adding the component file.
In the path
<config directory>/custom_components/<component name>
the <config directory>
refers to the .homeasssistant
folder where there’s the configuration.yaml
file too?
I used both the link you posted as well as this one: https://home-assistant.io/developers/add_new_platform/
As for adding the component, yes you are on the right track with the directory. In this case, because it is a climate platform, it would go in:
<config_directory>/custom_components/climate/<your_climate_component>
You would also need to a the component in your configuration.yaml file.
Yes, the <config_directory>
refers to the folder that has the configuration.yaml file is in which in your case sounds like the .homeassistant folder.
I tried with your demo climate component, but I think there’s something wrong with my configuration. This is what I do:
I put the demo.py
file into the .homeassistant/custom_components/climate
folder
I add to configuration.yaml
these lines:
climate:
- platform: demo
I add to the room I use as test (so in the groups.yaml
) these lines:
view_room_1:
view: yes
entities:
- group.room_1
- climate.climate_demo
but nothing appear on the Web UI. Is there any wrong data?
