I’ve got this automation —>
- id: door_left_open
alias: ‘Notify if the door is left open for 5 minutes’
platform: state
entity_id: binary_sensor.door_window_sensor_158d0001bf91aa
to: ‘on’
for:
minutes: 5
- service: persistent_notification.create
message: Door left open
Is it possible to set the number 5 as a variable, to use it in the alias+the for loop ?
Not in the way you’re thinking, but the concept is possible using a template trigger following the last updated attribute for your entity.
Or you could use a delay and condition in your action, there’s lots of creative ways to achieve it, depends on the circumstances which is best.
Thank you for your reply, I thought there would be a super obvious way, as I’ve seen these kind of config
icon_template: >-
{% set battery_level = states('sensor.mailbox_battery')|int('unknown') %}
{% set battery_round = (battery_level|int / 10)|int * 10 %}
{% if battery_level == 'unknown' %}
mdi:battery-unknown
{% else %}
So I thought (incorrectly!) that I would probably be able to set variables with “set” somewhere before my door automation.
I guess that another way would be to use AppDaemon, setting vars would become very easy.
Yeah, the problem is that not everything accepts templates, so you can’t use:
for:
minutes: "{{template}}"
But you can replace the whole trigger with a template.
