I would like to create an “alarm system”, similar to commercial systems.
Here is what I envision:
I have an Android tablet in kiosk mode (via wallpanel.app)
Under normal conditions, it just displays the the normal dashboard that I have configured for the tablet
However, when an alarm is set (checking a device for a condition), it should display a full-screen digit display. This screen stays on until a specific PIN is entered
If the right PIN is entered, the alarm is disarmed and the system reverts to normal (including the normal dashboard)
Can I implement something like this with Lovelace/HA? How?
Hmm, this I have already and it integrates with SimpliSafe by default. I actually use it as part of my dashboard and to show alarm status.
However, not as I want: First, there is no pin code but only Arm Home, Arm Away etc. Second, I really want to dynamically change the dashboard: In an event of alarm triggered, ONLY this thing should be shown, with the PIN and it should only disappear after the right pin has been entered and the alarm disarmed.
… Also this one I just got working and set up. I display HA just as usual. And even MQTT I use to read out sensor data. But sending commands I have not done yet.
How would you go about showing a different dashboard/PIN code via MQTT and execute an action (*) if PIN is entered correctly?
(*) Action: disarm system, change dashboard back to normal state.
