Here are some findings, that may helps others…
After integrating up my new Fibaro Door/Window Sensor 2 via MQTT, I wondered why I failed to do automations with it.
For the quick ones, for door open/close, you get a value 22/23 and not a binary state AND whatever you do, at least at the moment, querying these values from that device never succeeds in automations.
Here is the procedure to make automations run
- If not already done or present, go to your
configuration.yamland create the following entry right next to the similar ones:
template: !include templates.yaml - Then create a file if not exists named
templates.yamlon the same level as the other includes. - Add the following to this (new) file, replace
sensor.xxxwith the one how you have it and set the name according your needs:
# collected templates
# device_class: door: on (true, 22) means open, off (false, 23) means closed
- binary_sensor:
- name: Terrassentuer
state: >
{{ is_state_attr('sensor.wohnzimmer_terrassentuer_notification_access_control_door_state', 'value', 22) }}
device_class: door
icon: >
{% if is_state_attr('sensor.wohnzimmer_terrassentuer_notification_access_control_door_state', 'value', 22) %}
mdi:door-open
{% else %}
mdi:door-closed
{% endif %}
- If you have more of these sensors, just add more
- nameblocks. - Restart HA
- Add a new automation and add two new trigger
states, both referencing the new entity (name). For the first one set thetostate toopenleavingfromempty and set a delay (eg 8s, if required), while for the second one you setclosewith 3s. The trigger will now run on any state change. - For playing around, you may want to first set a service action and add log with just a dummy text to see if it works. See the HA logbook for changes. You can simply disable that action later on.
- Then, add a condition to actions and use the formerly created new entity from the template (name). Based on what you want to achieve, select one state (open/close) and a task what should happen. In my case it was to temporarily disable a thermostate, using the else condition to get it back.
- Set an automation mode, I used
restart - Give it a try and open-close the door.
Quite easy - if you know how …
