I’m using History Explorer custom card which most important task is to monitor humidity levels inside an indoor groow room (agriculture). Its cruicial to keep humidity levels very stable (61-62%).
- Green line represents humidity.
- Red stripe represents on/off state dehumidifier.
- Blue line represents power in Watt of the above.
As you can see from green line at most of time humidity fluctuate in range 61-62 rH. Thats fine. I want to keep it that way.
The issue here is the fluctuation in range off 61-65 coming up every 20 min lasting for about 20 min. This is obviouselly caused by automated dehumidifier. I would like to fine tune the automation to get stable levels 61-62 at all time.
I think a helpfull tool would be first to create a boolean sensor which could be included to history graph’s timeline under dehumidifier on/off state. I would like this sensor to indicate 2 states:
- Stable. When humidity changes oscilate in range of 1%
- Unstable. When humidity changes oscilate in range greater than 1%.
How can I create such sensor as template in configuration.yaml?
