In this forum I did check how to create fixed decimals at a sensor value.
I did found the format extension and tried that like:
magnetron_energie_today_euro:
friendly_name: "Kosten magnetron vandaag"
unit_of_measurement: "€"
icon_template: "mdi:currency-eur"
value_template: "{{ '{:.2f}'.format(((states('sensor.magnetron_energie_daily') | float) * (states('sensor.dsmr_day_consumption_energy_supplier_price_electricity_delivered_1') | float)) | round(2)) }}"
Using: ‘{:.2f}’.format for formatting two decimals
But it stil gives:
What am I doing wrong?
Thanks for the help
myle
(StePhan McKillen (Other kiwi Here))
June 29, 2021, 8:31pm
2
If paste it into templates do you see what you want
Off top head in your profile there a number format setting
Thanks for your answer. I didn’t think about that.
There it shows indeed a template of 2 decimals:
But in the card not
koying
(Chris B)
June 30, 2021, 7:05am
4
Which card are you using? Doesn’t look like plain “entities”.
It might itself do a conversion to float, which would make your forcing to 2 decimals useless.
My Yaml code looks like this:
## Magnetron
- cards:
- name: Magnetron
styles:
card:
- text-transform: uppercase
- font-size: 125%
- color: 'var(--dwains-theme-accent)'
- border-radius: 0%
- font-weight: 100
- letter-spacing: 10px
- --mdc-ripple-press-opacity: 0
- cursor: initial
type: 'custom:button-card'
- cards:
- entities:
entity: sensor.bw_8_magnetron_power
name: Huidig energieverbruik (24h)
font_size: 80
hours_to_show: 24
line_width: 2
hour24: true
points_per_hour: 2
decimals: 0
show:
animate: true
fill: true
icon: false
labels: false
graph: line
extrema: true
average: true
theme: ios-dark-mode-blue-red
type: 'custom:mini-graph-card'
- aspect_ratio: 1/1.2
color: 'rgb(150, 150, 150)'
entity: switch.bw_8_magnetron
icon: 'mdi:microwave'
show_state: true
lock:
enabled: true
#enabled: '[[[ return entity.state === 'on'; ]]]'
duration: 10
unlock: hold
#exemptions:
# - username: test
state:
- color: var(--disabled-text-color)
value: 'off'
icon: mdi:microwave-off
value: 'on'
styles:
name:
- font-size: 10px
state:
- font-size: 15px
- font: bold
type: horizontal-stack
- entities:
- entity: sensor.magnetron_energie_daily
- entity: sensor.magnetron_energie_today_euro
- type: custom:fold-entity-row
head:
type: section
label: Meer informatie
entities:
- entity: sensor.magnetron_energie_yesterday
icon: mdi:counter
- entity: sensor.magnetron_energie_yesterday_euro
- entity: sensor.bw_8_magnetron_kwh
name: Totaal energie verbruik
secondary_info: last-updated
type: entities
type: vertical-stack
It’s about the entities
koying
(Chris B)
June 30, 2021, 1:15pm
6
I’m pretty sure the number gets converted to float, maybe at localization level.
You might want to try playing with those settings.
I tried. to change as you mentioned but no change unfortunately.
The strang part is that if not using the format template it shows 1 digit in result:
and using format template it says two digits in result:
but in the card at frontend it is not showing two digits:
That is what i’m confused about
Change number format in user part as you mentioned is not effect the result also
