How to Create Sensors for Batteries from other Entity Attributes
Is it possible to create new battery sensor from an existing attribute?
E.g. from my hive devices
Txs
Ok figured it out - here if it helps someone else
    sensors:
      hive_underfloor_battery_level:
        friendly_name: "Hive Underfloor Battery"
        value_template: '{{ states.climate.underfloor_heating.attributes.battery_level|replace("%","")}}'
        device_class: battery
      hive_central_heating_battery_level:
        friendly_name: "Hive Central Heating Battery"
        value_template: '{{ states.climate.central_heating.attributes.battery_level|replace("%","")}}'
Wow, so grateful you posted this, solving it yourself! It just saved me a ton of time! :trophy:
Hey all,
Thanks for the solution! Update for current home assistant 2022.8, adding to the statistics by using state_class so you can track how long your batteries last :zap:
template:
  - sensor:
      - name: "My Sensor Battery Level"
        unique_id: my_unique_id_123  # optional; allows more configuration to entity e.g. icon customization to occur via UI
        state: "{{ state_attr('sensor.my_sensor', 'battery_level') }}"
        unit_of_measurement: "%"
        state_class: measurement
Note: if using state_attr() in the template, the sensor will be “unknown” until home assistant starts. This can be useful to ensure that incorrect values aren’t reported from an entity until it’s initialized.
Reference
