Cybolord
(Cybolord)
October 11, 2023, 10:33am
1
Hey folks,
I’m successfully using Sonoff RFBridge to Receive 433Mhz signals and send them to MQTT server topic.
First try: created one binary sensor in configuration.xml and it works like a charme.
mqtt:
binary_sensor:
unique_id: deckenfluter_0
state_topic: "tele/tasmota_rfbridge/RESULT"
value_template: "{{ value_json.RfReceived.Data }}"
payload_on: "545533"
payload_off: "54553C"
for now I would like to create several MQTT binary sensors without success; HA is starting but only the last (!) entry in my list of ‘unique_ids’ is accepted; so what is the right syntax to get it working in configuration.yaml, please?
Kind Regards from Cologne
MassiPi
(Massi Pi)
October 11, 2023, 10:39am
2
post your multiple sensor code
quite sure you added something in eccess (i.e. mqtt: )
tom_l
October 11, 2023, 10:40am
3
Can you please post your attempt to add more than one sensor and format it properly for the forum as per the instructions here: https://community.home-assistant.io/t/how-to-help-us-help-you-or-how-to-ask-a-good-question/114371#oneone-format-it-properly-16
Cybolord
(Cybolord)
October 11, 2023, 11:01am
4
WOW! what a response time!
here’s what I tried in configuration.yaml to get more than one sensor working:
mqtt:
- binary_sensor:
qos: 1
- binary_sensor:
unique_id: kaminlampe_0
payload_on: "5455C3"
payload_off: "5455CC"
qos: 1
- binary_sensor:
unique_id: kugellampe_0
payload_on: "501703"
payload_off: "50170C"
qos: 1
mqtt:
binary_sensor:
- unique_id: deckenfluter_0
qos: 1
- unique_id: kaminlampe_0
qos: 1
- unique_id: kugellampe_0
qos: 1
More general:
mqtt:
binary_sensor:
- unique_id: ...
- unique_id: ...
- unique_id: ...
- unique_id: ...
number:
- unique_id: ...
- unique_id: ...
I’ve just realized that documentation for this is very hidden. Maybe the examples on the pages I’ve listed above should be updated. @Cybolord would you be willing to invest the work?
The part of documentation that explains my format can be found here: https://www.home-assistant.io/integrations/mqtt/#yaml-configuration-keyed-and-bundled-by-domain
Cybolord
(Cybolord)
October 11, 2023, 12:55pm
7
Great stuff! Thank you very much, ThomDietrich!
It’s working like a charme - you saved me a lot of time
